Steering shaft/box clearance issue
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
Just reinstalled my steering shaft and box. Its been a while since i pulled them off and cant remember how tight the rag joint was with the steering box. I bolted the shaft to the steering column then the steering box to the frame, however it seems that their is some space betweent the rag joint and steering box. I tried prying the rag joint as close to the box as possible but it doesnt look right.
Is there supposed to be that much space between the rag joint and steering box?
Any help greatly appreciated!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Steering shaft/box clearance issue
1. Install the upper coupler on the steering shaft and install/tighten the bolt.
2. Pull down on the shaft to install on steering gear stub. The coupling must be fully seated so splines are not visible between coupler and gear. Install/tighten the bolt.
JamesC
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Should the bolt line up with the grove in the gear stub?
thanks for your time!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The pinch bolt at the bottom needs to go through the notch on the shaft of the box.
If memory serves, you have to REMOVE the pinch bolt for the thing to slide on... it's supposed to fit in that groove to keep it from being able to come off but will also not let it go back on.
Some pics in the link below that may or may not be useful:
https://www.thirdgen.org/forums/susp...ing-shaft.html
JamesC
JamesC
Car: 92 Camaro Z
Engine: LS 5.3 LM7
For some reason the steering shaft was compressed in and wouldnt reach far enough. Once i got it extended it bolted right in, as you guys instructed.
Thanks Everyone for your help! I would never be able to finish this project without TGO Members committing their time to helping others!
Fronzizzle
Mar 18, 2019 08:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
gixxer92
Sep 1, 2015 04:32 PM
