Power Steering problem
Old Mar 27, 2012 | 07:27 PM
383RAT's Avatar
Car: 1988 Firebird Formula 350
Engine: L98 383 cubes Multipoint FI
Axle/Gears: Ford 9 inch with 3.70 gears
When I pulled my motor last spring I decided to replace the power steering cooler line because it was all corroded and the replacement was inexpensive. I went ahead added a bit of fluid today started the car and the power steering doesn't work. So I decided to pull the low pressure return to see if the fluid was going all the way around and it was. I reattached the line added fluid and the power steering still doesn't work. Does anyone have any ideas what may have happened or is there something else I need to do? Thanks
I tried the air bubble removal procedure for 10 min it had no effect. I found no dirt in system when I drained it.
Last edited by 383RAT; Mar 27, 2012 at 10:06 PM. Reason: Further notes on what was tried
Old Apr 12, 2012 | 10:45 PM
383RAT's Avatar
Re: Power Steering problem
Well never mind all. I found the problem the pressure relief valve in the pump was sticking. The plug that slides back and forth had a scratch on it. I polished it with Scotchbrite and now the power steering has worked fine for the last 40 miles.
I guess some type of contaminate got into the system, but i'm unsure what the heck it was to scratch the steel valve plug like it did.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
db057
Aug 22, 2015 08:17 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
