Plz help
Car: 87 firebird did V8 swap
Engine: sbc 350
Transmission: 700r4 shift kit and stall
Plz help
Ok so I bought a set of Camaro front coil springs cause I need then to do v8 swap but will they work on my firebird I hope I didn't mess up and if not is there a wa to make the work
Car: 92 Camaro RS, 93 Caprice Classic
Engine: 3.1L V6, 5.0L V8 + 700r4 on both
Transmission: Rebuilt 700r4 in the Camaro
Axle/Gears: Stock with 3.23s ...3.73 later?
Re: Plz help
It's my understanding that dimensionally the springs are the same, as the basic suspension geometry is the same between the Camaro and Firebird. The springs will fit fine, no stress.
Last edited by TheEndofanEra; Apr 7, 2012 at 04:59 PM. Reason: Springs don't sing and fins aren't fine. ;)
Re: Plz help
The Firebird and Camaro are the in fact same car, with minor differences in sheet metal wrinkles and sticker packages. Identical in every way as far as construction.
The springs do not care what version of those things are around them.
Engine: sbc 350
Re: Plz help
ok sweet and I'm guessing its not possible to put them in without a spring compressor either is it
Re: Plz help
I've heard its possible to change them without a spring compressor, but I'd use a spring compressor myself. There's plenty of info on ways to change them if you do some looking.
Andrew Prakash
Sep 8, 2015 11:48 AM
Amrish
Nov 9, 2001 11:33 AM
