Lowering help
Car: 91 camaro rs
Engine: 305 (350 vortec in dec.)
Transmission: Wc-T5
Axle/Gears: 3.08 (3.42 in dec.)
Lowering help
Plan on lowering the maro soon and don't wanna spend the money on springs until I know I like the look. The sportline kit says 1.0"/1.6" (r/f). That's the drop I think I want: I'm going to cut my springs to get the idea, then based off what I see, get new "stock" springs or lowering springs. My question is, how much do I cut off the spring to drop it 1.0" (r)/ 1.6" (f)? Any help would be great, thanks!!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Lowering help
because of many variables, no one will be able to tell you that. You will have to make a cut, put it back together, move the car to settle things, check, and repeat if needed.
however, once you cut your springs and get the height where you want it, why buy more springs?
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
Re: Lowering help
Cut mine about half a coil in front and 3/4 coil in back and dropped 1.6"F and 1.5"R. It took a couple days to settle btw.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Lowering help
Spend the extra $ on Ground Control Weight Jacks & you can dial in the ride height YOU want & are not restricted to just what some spring makers sells you.
MrPackstin
Oct 25, 2017 08:09 PM
