Ooooppps !!!! My Rear Bottomed out!!!!!
Old May 3, 2012 | 03:09 AM
Possumz's Avatar
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 5 Speed
Axle/Gears: 3:42
Recently the rear suspension bottomed out while I was hauling some extra weight that I had put across the rear storage area (80 pounds) and of course the tools I had in there as well (Another 80 or more). This is my daily driver 92 RS Camaro. Bottomed out well enough to break both rotton bump stops. So the problem is now my car will bottom out without any weight in the rear area and also developed a shake when letting out the clutch that wasnt there before. I have picked up new bump stops and will install those tomorrow. What else do I need to fix. If you do the old push down est on the rear of the car it does not bounce around.
Old May 3, 2012 | 10:34 AM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
Re: Ooooppps !!!! My Rear Bottomed out!!!!!
Broken rear spring?
Old May 3, 2012 | 10:47 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Yep...Sounds like a broken or just severely sagging worn spring if it is still bottoming out with zero extra weight. Of course....Carrying 190lbs in the back didn't exactly help either.
But I gotta ask.....Bottoming out with zero extra weight? Bottoming out when? Pushing by hand? Do 80mph across railroad tracks & speed bumps?
Old May 4, 2012 | 08:31 AM
Possumz's Avatar
Car: 1992 Camaro RS
Engine: 3.1
Axle/Gears: 3:42
It likes do bottom out on small dips in the road. I have two that I drive over daily and if I dont hang to the left lane where the dips are it will bottom out. Thing is it dont sag and dont look like its broke. Guess I will pick up some springs and may as well get some shocks too as my VA inspection is coming up next month. Thanks guys.
Old May 4, 2012 | 09:36 AM
tango1112's Avatar
Car: 1982 Firebird
Engine: 355 CID
OUCH... No fun... Does sound like springs.
Old May 4, 2012 | 10:08 AM
SCCAjunkie's Avatar
Car: 84 Z28
Broken springs *should* be easy to spot if you crawl under the car.
With the issue with the dips, it definitely sounds like you're in need of shocks as well.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Zeek1041
Aug 21, 2015 08:45 PM
