rear suspension adjustment and starting figures
Car: 88 gta
Engine: 350 turbo
Transmission: t5
Axle/Gears: 4.56
i need the factory lengths of the lower control arms and panhard bar. i have one way adjustable ones and the axle is a moser 9 inch and when i put c6 wheels on it, the one passenger side wheel doesent go on. drivers side does rub a touch i think the axle isnt square in the car. i have 2 inch spacers on the wheels and the tires are 285/45?r19.
tq arm is factory btw.
car isnt lowered either. also if can tell me how to get it to fit without beating the wheel wells in that would be great! i may just add a 1/4 slip on spacers to the 2 inch ones.
car is a 1988 firechicken gta. dont know if it matters.....
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: rear suspension adjustment and starting figures
When I put my Double Adjustable LCAs on, I just matched them up to the stock LCAs I just took off.
Car: 88 gta
Engine: 350 turbo
Transmission: t5
Axle/Gears: 4.56
this car has been sitting on stands for a while and i threw out the old ones long ago. now i want to verify the fatory lengths and position on the axle then go from there.
Car: GTA
I happen to have 2 pairs of spare stock LCAs sitting around.
I know my pics looks a little off at angle, but the center to center of the bolt holes actually is dead center between 19 1/4" & 19 3/8".
Car: GTA
I'd dig out the spare PHB & get you a measurement on it but honestly? The stock length can suck. My rearend was offset by about a full inch on stock springs, stock wheels & stock tire sizes.
I say just adjust your PHB until the rear is centered.
hectre13
Dec 11, 2023 08:14 AM
