1986 suspension
Old May 9, 2012 | 09:33 PM
2004chevyman's Avatar
Car: 1986 camaro
Engine: 2.8
Transmission: 700r
Axle/Gears: 243
1986 suspension
hello people ,need to ask a question ,i have a 1986 berlinetta camaro ,and i was wondering what would be the best suspension to use , i would like a very smooth ride if i can get one ,and another question i have i have done my rescher on my camaro ( excuse my spelling) but the 86 berlinetta 4,479 was made because of low sale voloume will this make this camaro a rare fine just asking thnks for any info
Old May 10, 2012 | 09:30 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Re: 1986 suspension
Starting with the suspension, there is no single answer. UMI makes great products, BMR makes great products, Founders is inexpensive and good from what I hear, and Spohn makes great products.
First plan of attack, for me, would be to get it in working order. If your steering components are original, get rid of them. Replace them with a kit of your liking. Spohn makes a steering rebuild kit for around $300 that is good. Otherwise you can go to Rockauto and piece together a kit, of the same components, for less. If your struts and shocks are worn out replace those. KYB makes factory replacements that work rather well. If you have a higher budget go for Koni yellows. They are rebuidable and adjustable. They make great replacements. I had the KYB in my car for a long time and they worked great, until I lowered the car a lot. Then I would look at the bushings, swaybar, a-arms, etc. If they are cracked replace them. That will get you going and make a huge difference in ride quality. If you get that done quickly then you can move onto quality tires, subframe connectors, adjustable panhard bar, adjustable LCAs, adjustable torque arm, adjustable caster camber plates, adjustable a-arms, tubular k-member, and the list goes on and on and never ends. It is addicting.
On how rare your car is, it isn't. That is not meant to be mean, but there were TONS of third gens built and unless you find someone looking for that specific car it will bring no more than a normal third gen of those specs.
Old May 10, 2012 | 09:48 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Re: 1986 suspension
if a smooth ride is what you seek then you are likely best off getting some very tall tires, and parts store replacement shocks
LT1Formula
Oct 8, 2015 08:34 PM
Gordonr1973
Sep 29, 2015 11:59 AM
