My Frontend rebuild
Old May 19, 2012 | 06:06 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
My Frontend rebuild
Really wasn't cheap at all.
UMI K-member
UMI A-Arms
UMI Tie-Rod adjuster sleeves
UMI Solid motor mounts
USA made Tie-rod ends (Inner and Outer)
USA made Idler Arm
USA made Center Link
MOOG Swaybar end links
MOOG Swaybar bushings
Eibach Pro-Kit
Founders Performance Camber/Caster Plates
KYB AGX shocks
Reman ACdelco quick ratio steering box
Jeep steering shaft
I could of spent more on shocks, but I think the KYBs will be fine. I have a 34mm sway bar and a wonderbar. This suspension is going to be holding a 383 stroker with a Holley Avenger Stealth Ram system. This car was a V6 car. Going to use the Holley system instead of a GM ECM. Now for pictures! Don't mind the brake lines, I haven't mounted them yet.
Also replaced the rotors, pads, calipers, wheel bearings, dust caps
UMI is the best. Everything fit great and went in without a hassle.
Attached Thumbnails My Frontend rebuild-10.jpg   My Frontend rebuild-photo.jpg   My Frontend rebuild-photo-2-.jpg
Old May 19, 2012 | 06:07 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Re: My Frontend rebuild
More
Attached Thumbnails My Frontend rebuild-photo-4-.jpg   My Frontend rebuild-photo-6-.jpg
Old May 24, 2012 | 09:28 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Just finished up the long block
4 bolt main
Eagle 383 balanced rotating assembly
Comp Cams XE274 K-kit
Edelbrock Etec-210 heads
Comp Cams 1.6 Roller Rockers
Attached Thumbnails My Frontend rebuild-motor3.jpg   My Frontend rebuild-motor4.jpg   My Frontend rebuild-motor1.jpg
Old May 25, 2012 | 12:46 PM
UMI Sales's Avatar
Nice build! Thanks for choosing UMI and for the kind words.
That engine looks pretty sweet. I'm digging that cylinder head and cam combo. That car should rip.
ramey
Old May 25, 2012 | 06:48 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Thanks for making such great products! I was so happy today when I didnt have to remove the A-Arms to swap motor mounts. Your guys stuff is really the best!
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
