New suspension parts installed... couple pics
Car: 89 IROC-Z
Engine: 355ci SBC
Transmission: TH700R4 - 2500 stall
Axle/Gears: 3.70 9 bolt
I'm doing a complete tear down and rebuild of my IROC, engine is at the machine shop right now so I'm installing all of my new UMI goodies and other parts that needed replacing. So far I'm impressed with the quality of UMI's parts and look forward to seeing how they perform once the car is on the road. Here's a small break down of what I have installed...
UMI Lower Control Arms
UMI Panhard Bar
UMI Caster / Camber plates
UMI Sub frame connectors
Koni Yellow struts and shocks
Eibach sportline springs
BMR torque arm
Poly A-arm and sway bar bushings
UMI strut tower brace
All new Moog center link and idler arm with UMI adjusters
UMI Panhard Bar
BMR torque arm
Car: 89 IROC-Z
Engine: 355ci SBC
Re: New suspension parts installed... couple pics
Here are the Caster & Camber plates
Car: 89 IROC-Z
Engine: 355ci SBC
Koni front struts just hanging on the strut tower, need to remove the sleeve from the old struts and install them on the new ones. Also new steering components.....
Car: 89 IROC-Z
Engine: 355ci SBC
L-98 block and heads in the truck, currently in the machine shop and will be out on Monday. WC T-5 cleaned and ready to go in...
Car: 87' IROC
Options include:
no dust shields
4x4 dust shields
something else
Car: 89 IROC-Z
Engine: 355ci SBC
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
No...
Car: 87' IROC
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
utfan01ss, thanks for posting pics. Always good to see how parts go together especially new ones! I have most of the same suspension parts from UMI and Koni's. Hopefully at end of summer I'll be ready to install them.
Engine bay looks great!
Car: 89 IROC-Z
Engine: 355ci SBC
Couple more updated pics... got my engine back from the machine shop and put together. Going to drop it in on Friday and hopefully have it running this weekend.
Front suspension installed, still have to purchase Poly sway bar bushings and end links for the front. I'll get that done tomorrow....
Car: 89 IROC-Z
Engine: 355ci SBC
Another engine bay shot, front suspension and brake rotors... and the pretty freshly machined L-98 from the machine shop
Car: 89 IROC-Z
Engine: 355ci SBC
Few more engine pics as I put it together. All scat internals, LT4 hot cam, Comp Magnum roller tip rockers, Trick Flow roller lifters and a few other goodies.
Car: 89 IROC-Z
Engine: 355ci SBC
I put my valve covers and headers on just to see what it looks like, not bad. Can't wait to put my SLP runners and polished upper plenum on with those aluminum parts. Hopefully it will look good. I have MSD wires, distributor and coil which are red. Just a few simple details here and there.
Car: 89 IROC-Z
Engine: 355ci SBC
Thanks! Yeah I'm excited to get it all put together. I've invested lots of money into this car and can't wait to show it off. Not too many nice third gens around here.
Car: 1987 Trans Am
Engine: LQ9/L92
some really nice looking toys you've got going onto that car. keep up the good work!
Car: 89 IROC-Z
Engine: 355ci SBC
Almost got the engine finished up. Had to order another drivers side serpentine belt bracket since I broke mine in half when I tore the motor down. It should be here before Friday so hopefully I'll have the car on the road this coming weekend. Everything is going well so far... except my car is sitting uneven. The passenger side front fender gap is 1.5 inches higher than the drivers side. I haven't installed the front sway bar or wonder bar and haven't lubed the suspension or steering components so I'm not sure if that has something to do with it or not. I'm going to double check everything before I drive it though. Hopefully its nothing major.
All in all the project is moving along...
Car: 89 IROC-Z
Engine: 355ci SBC
Car: 89 Iroc
Engine: 305TPI
Car: 1991 Camaro Z28
Engine: 305 TBI
Transmission: 700r4 w/B&M Shift Kit
Is those Tie Rod Ends Moog? My inner has the grease fitting on the back like yours does....what the #@# do you use to get grease in it....not enough clearance for my gun.
Car: 89 IROC-Z
Engine: 355ci SBC
No, the center link and idler arm both are Moog parts but the tie rod ends are Duralast from Autozone. Honestly they **** me off, I took mine loose and lowered them down to where I could get the grease gun on the fittings. Once I greased it to where the boot was filling up I installed them and torqued the nut down. I'm going to check and see if the Moog tie rod ends have the fitting on the sides, where they should be. It really is a PITA having the fittings on the back where its against the K-member.
Engine: 305 TBI
I know exactly what you mean. I just put the same ones on my car and had to do the exact same thing. I guess I'm going to have to go get a low profile 90 degree bend for my grease gun to hit them up now and then. Supposedly, the Duralast Tie Rod Ends and Centerlink are made by Moog for Autozone. This is according to my local store manager. But they do have the same part numbers as Moog.
Axle/Gears: '01 3.42 10 bolt
i think you have the wrong inner tie rod ends. i ordered moog inner rod ends through rock auto and mine are on the end of the tie rod so there will not be an issue getting the grease gun on it.
