How do I rotate my new idler arm?
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
This may be a stupid question but I just got my new Moog Idler arm and I can't get the dang thing to rotate.
How do I get it to look like this:
Instead of this:
Instead of this:
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: How do I rotate my new idler arm?
put in in a vice and pull on it on bolt it in and move it.
Engine: 5.7 TPI L98
Engine: Lb9
Transmission: M20
the idler arm is suppose to move right and left. when they are new they can be real tight . sounds like the old one was bad or you had pivoted the joint in a bind and forced it
Engine: 5.7 TPI L98
Engine: Lb9
Transmission: M20
No problem, sometimes there is movement when you mount the idler to the frame make the center link look level or as close too it if there is movement. HTH
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
