Difference b/tw XH and WS steering box and 15 & 16" wheels
Old Jun 17, 2012 | 11:54 PM
eddie jr's Avatar
After a lot of research I was under the impression that 15" wheel cars (or those with sport suspension) had the WS steering box with the quick 12.7:1 ratio and 70* turning radius and the 16" wheels had the XH box also with the 12.7:1 ratio but with a narrower turning radius (64*) due to the wider wheels. I also was under the impression that along with that the steering stops on the control arms were different as well.
I had 15" trans am wheels and the quick ratio (factory) and i am pretty sure i can faintly make out a WS on the box. I am putting on 16" formula rims and a box out of a 91 GTA that i can see an XH on it, however, when i put this new box on, the wheels still turn the same distance and hit the current stops on the control arm.......what gives? I was all ready to modify the stops because i though these boxes had a different turn radius. WHat exactly is the difference between them then?
Old Jun 19, 2012 | 01:06 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Difference b/tw XH and WS steering box and 15 & 16" wheels
My '92 RS with the factory 15" wheels has the JL box. Which is an OK box.
Some info I have on the XH & WS boxes:
Both have the same 12.7 ratio
XH is higher effort at 28 - 34, with 32* in each direction
WS is lower effort at 24 - 30, with 35* in each direction
I guess the 3* less in each direction doesn't make enough of a difference to prevent hitting the stops.
RBob.
Amillionoh7
May 24, 2020 08:01 AM
Fronzizzle
Mar 18, 2019 08:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
