ball joint movement
Old Jun 29, 2012 | 12:06 AM
88 TA GTA's Avatar
Car: MSD Dist., Crane Hi 6 ignition
Engine: 350 - 50 over, S/R Torquer Heads
Transmission: T56 - Originally a 700R4
Axle/Gears: 9 bolt posi with 370
ball joint movement
Hi I was checking brakes due to clanking noise while driving and checked found the inner pad was a bit loose, but when I apply brake it isn't and moves out to rotor and stops it.
When I held the caliper tight to check for movement it was tight and the ball joint had a bit of play and made a noise. I added grease and there was no more movement and noise was almost completely gone.
I don't believe it is normal for there to be movement grease or not, correct?
Not sure if they have ever been done car has just over 100 000 miles
And what would make the inner pad have play? Caliper moves fine.
Thanks in advance
Old Jun 29, 2012 | 09:55 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: ball joint movement
The balljoint is shot, replace them on both sides.
The pad should not be loose either, it could be worn, or the rattle clips between it and the caliper are worn or missing. Check that out, and since its apart, see if the rotors and pads are good or worn and replace as needed
Old Jun 29, 2012 | 08:05 PM
88 TA GTA's Avatar
Thanks, very much appreciated! I did check pads and rotor they look 70% or better but not sure of the clip, didn't pull off caliper yet.
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
