someone here who uses flamingriver power steering rack?
Hi.
í´ve want to get rid of the steering gearbox and go with a power steering rack instead and find this:
http://www.flamingriver.com/index.ph.../s0005/FR40022
what do you think about that? the camaro has 6" travel lenght if i´m not wrong. and this has over 6".
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: someone here who uses flamingriver power steering rack?
Wouldn't it be easier to buy a kit designed for a third gen from a vendor such as Spohn. That way you know it will fit and work properly. A steering rack isn't a simple bolt on. I'm not even sure if the mounting brackets can be easily welded to the stock k-member. It's much easier to do with a tubular k-member.
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
colton_carlson
Mar 8, 2019 12:21 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
