BMR Adjustable Torq Arm
Old Oct 26, 2012 | 03:55 PM
86F.BiRD's Avatar
Car: 1986 Pontiac Firebird Base
Engine: SBC 350
Transmission: Borg Warner T-5 World Class
Axle/Gears: 4th Gen Rear with 3.73s
I just put the eibach sportline kit, kyb shocks, BMR adjustable torq arm and BMR adjustable panhard bar on my car. The question i have is has anyone seen clearance issues with the underside of the car and the adj. torq arm? because mine rubs in a small area.
Old Oct 29, 2012 | 11:45 AM
BMR Tech's Avatar
Former Sponsor
Re: BMR Adjustable Torq Arm
Hey there, yeah, sometimes aftermarket torque arms will rub the tunnel because they are a larger construction. Just the nature of the beast, unfortunately. A solution to this is to get a block of wood and mallet to "clearance" the area the torque arm rubs. Or, if you haven't already tried, use the other set of holes to move it away from tunnel more.
- Kevin
Old Oct 29, 2012 | 02:47 PM
86F.BiRD's Avatar
Engine: SBC 350
Just adjusted everything less than 30 minutes ago and now it doesn't rub
Old Oct 30, 2012 | 02:39 PM
BMR Tech's Avatar
Former Sponsor
That's good to hear. What adjustments did you make that helped the TA clear better? I ask because the issue is a common issue on a lowered car so, if it becomes an issue, we tell people to perform this mod. If there is an alternate method, I would love to know.
- Kevin
Old Oct 30, 2012 | 05:03 PM
BADCAM70's Avatar
Car: 89 IrocZ
Engine: 5.7
Transmission: TH700
Axle/Gears: 2.77
I had the same problem with another aftermarket company torq arm and i adjusted my panhard bar,i have the Eibach pro springs,so a lowered car with any kind of aftermarket torqarm i would recomend a adjustable panhard bar also just to make sure.
Regards Mats
Old Nov 12, 2012 | 10:18 PM
AceBoogie!'s Avatar
Car: Camaro SS
Engine: 5.7
Transmission: 4l60e
Axle/Gears: 4.10
add LCA, PHB and TA and you have a good set up...Don't forget SFC
Old Nov 12, 2012 | 11:23 PM
86F.BiRD's Avatar
Engine: SBC 350
I just adjusted the adjustments on the torque arm, there were no mods neccesary. With the new torque arm, panhard bar, eibach Sportline kit, and new kyb shocks, my car now handles and rides like a new one. Next thing I want is subframe connectors, then the suspension will be complete
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
camaro1185
Oct 26, 2015 06:51 AM
luvofjah
Sep 10, 2015 10:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
