Rear End Poping
Car: 1992 Camaro RS
Transmission: N/A
Axle/Gears: N/A
Rear End Poping
i have a 92 RS camaro &the problem is sometimes when im pulling off (like at a stop light) mainly pulling off fast my rear end on the passenger side dose a popping thing... now i have replace the SWAY BAR END LIKNS on each side... PROBLEM still there. ANY ADVICE ?
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
Re: Rear End Poping
Mine has the same problem and a friend that owns a transmission shop told me its ny rear end. Might want to check it out and see the play it has. Possibly time for a rebuild??
Re: Rear End Poping
Engine: 2.8L V6
Re: Rear End Poping
Your rear end... the diff... idk other words for it. Just see if when you lift the rear up and turn the wheel you cant hear the rear popping. You may need to rebuild it sooner or later
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Rear End Poping
I would pull the differential cover and take a look if she was mine.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
