UMI A-arm torque specs
Old Jan 7, 2013 | 04:20 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
UPS is supposed to drop off my UMI A-arms tomorrow. I'm not sure if they come with instructions or not? If they don't does anyone know torque specs for the A-arms to K member bolts and the ball joint to spindle nut?? Thanks
Old Jan 7, 2013 | 05:02 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: UMI A-arm torque specs
When I installed my Spohn A Arms I used the Haynes manual. I think it was 85-lbs for the spindle nut and I think the stock rating on the inside which is like 50+ lbs made the tubular k member's brackets actually flex so I went with around 35 lbs. I wouldn't think the factory piece would flex though.
Old Jan 9, 2013 | 04:57 PM
Car: 89 Formula 350
Spoke to UMI the other day...60 ft.lbs. on the A-arms to K member bolts and 70 ft.lbs on the ball joint nut or a little more to line up for the cotter pin.
no green
Jan 9, 2016 09:22 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
