no holds barred
Old Jan 14, 2013 | 09:58 PM
APACHE JOHN's Avatar
Car: 1991 Z28
Engine: 350 TPI RAMJET COMING
no holds barred
I know coil over will save weight.... I'm all for that. But which handles the the best? that's what I really care about.
Old Jan 15, 2013 | 07:43 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Re: no holds barred
Less unsprung weight will help handling to a degree, but the best benefit for your car will likely beng able to fit the biggest tire possible under the car. A coil-over setup will limit your tire size significantly.
Old Jan 16, 2013 | 06:20 PM
Car: 1991 Z28
Re: no holds barred
I will stick with a 245/50/16
Old Jan 17, 2013 | 01:02 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Re: no holds barred
Coil over is one of the worst mods for handling you could do to these cars.
Old Jan 17, 2013 | 10:54 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: no holds barred
And fitting bigger and wider tires doesn't always = better handling. It all depends on alignment and other things. Wider and bigger might add unsprung rotational weight which is bad for handling and reduces acceleration, ofcourse this depends on the threshold between the added traction benefit vs the added unsprung weight.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
