anyone have any measurements to check the spindles?
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
looking at picking up a set of spindles from a junkyard for the LS1 brake swap, and would like to be able to check them to see of they are bent or otherwise out of spec. anyone have any technical drawings or anything like that?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: anyone have any measurements to check the spindles?
I wouldn't worry too much, they are very hard to damage and should be pretty obvious if they are messed up.
I have full size copies of the origional blueprints for the 1le spindles, if there are certain measurements you want I can get them
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
what is the difference between the 1le spindles and standards?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Essentially the ears have been cut off the standard spindle. You can see the modified 1LE spindle below:
http://web.archive.org/web/200605221.../1LEbrake.html
JamesC
JamesC
Car: 86 Camaro
also, i've seen people mention bending the arms for better Ackerman geometry, so it would be nice to have a good spec for that if i'm gonna do anything- might even make up a fixture for each side and a program to modify the spindles for 1LE or LS1 or whatever brakes on the cnc here at work in case others might want some cheapish modified spindles..
To add that when you do the 1LE modification, there is alot of undesireable casting that can be grind off the spindle to lighten it. I took an extra 1/4 lb off each side when I did my comversion by smoothing the casting lines off and strategically grining off alot of mass that was not critical near the sturt shaft bolt holes. Lots of radius grinding so it retained strength, but lost weight. light weight suspension parts is critical in good ride quality and perfomance handleing so every little bit counts when you add up all the parts plus wwheels and tires. Could be the difference of 10 pound per wheel if done right with care rather than not being aware of this weight importance. Its little things like this why people report their cars riding harsh. They put heavy brakes, heavey larger diameter tires and wheels that are also wider, they increase track width which in turn increases offset and cause more ariiculation weight through leverage, etc.
just another tip.
just another tip.
