Do I need an adjustable torque arm
Old Feb 25, 2013 | 07:40 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I need a torque arm.
Car will be a daily driver.
Mild tpi
t5 trans
stock rear.
Rear set up
adjustable control arms
adjustable panhard bar
bilstien shocks
lowered about 2" in rear
Was thinking about a jegster arm, like the idea of getting it off the trans, good price too.
Do I "need" an adjustable bar?
Old Feb 25, 2013 | 07:48 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Do I need an adjustable torque arm
Only if you're experiencing driveline vibrations under heavy load.
Old Feb 25, 2013 | 07:53 PM
Car: 1971 Camaro
Engine: 427
Cars in a million pieces right now, so I have no idea if there are any vibrations.
Old Feb 25, 2013 | 07:56 PM
I would say yes if it's lowered or you will be racing the car.
Old Feb 26, 2013 | 06:10 AM
Car: 1971 Camaro
Engine: 427
Lowered, yes.
Racing, no.
Old Feb 26, 2013 | 11:17 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
No you don't "need" one, but they sure are nice. I ran around years on the iroc with the stock TA 2" lowered.
Old Feb 26, 2013 | 11:19 AM
Car: 1971 Camaro
Engine: 427
Thats what I was thinking. For a street car I don't 'need' one, but the pricing is not much more.
I went ahead and ordered the Jegster adjustable one.
Old Feb 26, 2013 | 12:05 PM
It will be nice to be able to adjust pinion angle if you find that your car has a driveline vibration once you get it together.
Old Feb 26, 2013 | 02:29 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Personal experience: I wish I had ordered an adjustable one years back when I just randomly assumed a non-adjustable UMI TQ arm would do the trick.. It's still hooked up to the trans, and not adjustable so I cannot change pinion angle. If I could go back, I would have spent the extra 100$ or wtv it is to get adjustable atleast, and even the one that mounts to their aftermarket x-member to take the stress off the tranny tailshaft.
Old Feb 26, 2013 | 02:39 PM
Car: 1971 Camaro
Engine: 427
Good to hear, already ordered an adjustable unit.
Old Feb 26, 2013 | 08:57 PM
goliath88's Avatar
Car: 88 firebird convertible
Engine: 305 tbi v8
so youre just on springs, nothing else as far as suspension work?
Old Feb 27, 2013 | 04:58 AM
406TPI's Avatar
Car: 1985 IROC-Z
I used to just ride on factory iroc springs cut to the drop I wanted, everything else stockish. Now I'm on a different set-up all together.
Old Feb 28, 2013 | 08:20 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I went with the Spohn adjustable cross-member mounted (not tail shaft) with the heim joints. I like it, at least it feels like it made a difference. On shifts and sudden throttle I can hear the joint making a little noise, but I don't care.
Old Feb 28, 2013 | 08:29 PM
Car: 1971 Camaro
Engine: 427
That's the one I've been wanting, but my shopping list is so long, I'm trying to keep the budget down.
Trying to get the orange car back in daily driver status soon.
I'm driving my 71 camaro daily now.
Old Mar 5, 2013 | 04:36 PM
BMR Tech's Avatar
Former Sponsor
This is a common question I get asked. People believe that if they don't have vibrations now, they don't need to get an adjustable. Well that's simply not the case. The factory torque arm isn't what you would call "precise" and it's not a very solid part. Going to a more robust arm like our TA002 - which is set up for factory pinion angle - will be very solid and show how off your pinion angle actually is. If you're lowered 2-inches your rearend is 2-inches higher than it was when it left the factory, and you pinion angle is no longer set correctly. How far off you will be is going to vary by vehicle, but it's always just a good bet to go with adjustable and never have to buy another one again.
- Kevin
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
