Steering components
Old Mar 25, 2013 | 12:31 AM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Steering components
I'm about to upgrade my tie rod sleeves and was wondering if I should go with the hotchkis steel sleeves (62$) or another brands billet aluminum ? (35-45$) Surely the billets are stronger than stock right ?.. Also I was wondering if all 4 tie rod ends were the same or is there 2 of each 2 diff kinds ? Thanks !... And what y'all think bout tubular front control arms ? Just wondering .. And is it really hard to put a tubular k member in?
Old Mar 25, 2013 | 02:14 AM
andresinibus's Avatar
Car: 85 Z28 W/T-Tops
Engine: 383 crate engine edel carb n headrs
Transmission: ex700R4/NOW T5
Axle/Gears: 3.08 std
Re: Steering components
as far as the tie rod ends yes there is 2 of each 2 inner 2 outer they look the same but the inner ones have the grease fittings on the sides whereas the outer ones have them at the bottom for sleeves I used the regular ones from autozone I heard the aluminum r good I would suggest u replace the center link and idler arm as well and that's my 2 cents
Old Mar 25, 2013 | 04:06 AM
Car: 1991 firebird
Axle/Gears: 4.10
Yea I already replace center link about 10k miles ago .. And plan on replacing the idler arm as well .. Also thinking about the hotchkis bump steer outer tie rod ends but idk yet
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
Briandrex
Oct 5, 2015 06:20 AM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
