Torque Arm
Old Mar 26, 2013 | 01:59 PM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Torque Arm
Iam having a problem getting the drive shaft in because the axel is pointing up the torque arm is not in yet if I put the rear of the touque arm to the axel can I pull it down into place to get the driveshaft in any help on this one I really dont want to drop all the suspension! thank you.
Old Mar 26, 2013 | 02:01 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Torque Arm
Having a hard time understanding what you are trying to say.
Install the torque arm first, then install the driveshaft.
Any reason what you can't do that?
Old Apr 5, 2013 | 09:44 PM
Ingram78's Avatar
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
Re: Torque Arm
Stick a long screwdriver/pry bar in the rear yoke. With the u joint caps on ,And pry down.
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
