Will a 94 camaro Rearend fit in my 89 camaro
Old Apr 19, 2013 | 10:27 AM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Transmission: 700 r4
Axle/Gears: 342
Will the center chunk interchange be for I take it apart thanks
Old Apr 19, 2013 | 12:21 PM
Re: Will a 94 camaro Rearend fit in my 89 camaro
Yup
Too bad it'll be an Auburn
If it's even a limited slip at all, that is
Might not fit your axles though; about 90% or more of all 89 model cars still got the 26-spline ones
Old Apr 19, 2013 | 12:38 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Does you know what it takes to set up a ring and pinion? Do you have the tools?
Old Apr 19, 2013 | 01:23 PM
Doesn't have to do R&P if he just changes the "center chunk" (carrier); all that requires, is getting enough preload on the carrier bearings, and the backlash about right. Which can be done with a feeler gauge.
Old Apr 19, 2013 | 01:29 PM
Car: 1971 Camaro
Engine: 427
Assuming he knows how to do that.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
matthew911
Aug 12, 2015 09:38 AM
Vintageracer
Aug 11, 2015 08:13 PM
