Maximum caster numbers?
Old Apr 25, 2013 | 12:30 AM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
Axle/Gears: moser 4:10
I know most 3rd gen's are limited in adjustment to around 5 to 6 degrees. But if you could run more what would be the limit for a track car? I see the new Camaro's run 6.5 stock and the Vettes are 7.7
Old Apr 25, 2013 | 07:13 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Maximum caster numbers?
Without modifying parts or using aftermarket components, I was only able to get around 5* on my car.
The more caster you have, the straighter the car will want to go however, it also makes it harder to turn. Lots of caster is good for a drag car. It's not good for a road course/autocross car.
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
