Power steering delete.
Old May 3, 2013 | 09:07 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
Is it possible without breaking anything to just pull the ps pump and call it a day?
Posted from Thirdgen.org App for Android
Old May 6, 2013 | 12:38 PM
fenton06's Avatar
Re: Power steering delete.
Turning will be a bitch.
Look for an 84-up S10 manual steering box. Only downside is they're 7.25 turns lock to lock. Direct bolt in after switching pitman arms.
Old May 6, 2013 | 12:40 PM
mcrandrz's Avatar
Car: 1991 camaro rs
So like between the inner tie rod ends is the steering box?
Old May 6, 2013 | 12:42 PM
mcrandrz's Avatar
Car: 1991 camaro rs
And s10 pitman arm? Or just a new one
Old May 6, 2013 | 02:36 PM
SlickTrackGod's Avatar
On Probation
to turn the the front wheels left about 30* with a power steering box- it takes about 1 full turn of the steering wheel "assisted" because of the low ratio of leverage. Without assist, the force needed to turn the wheel that rapidly is like riding a road bicycle in top gear from a takeoff. You need to get a manual 'unassisted box" which is like a lower gear ratio/ higher leverage like an 25:1 ratio box rather than a 12:1 box that needs power assist. A manual box will take about two turns to get the same angle as a power box would do with one turn.
Squeaky8791
Feb 5, 2020 08:29 PM
Vintageracer
Jan 10, 2020 05:33 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
