spohn Pinto R&P
Old Jul 24, 2013 | 05:56 PM
transam84's Avatar
spohn Pinto R&P
Anyone have the Spohn Pinto R&P in their car?I. Am thinking about getting the Spohn setup with the K-member,a-arms,front coil overs and the pinto R&P.is the pinto R&P just a novelty or is it worth while for a stree car?
Old Aug 1, 2013 | 12:30 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Re: spohn Pinto R&P
There is significant amounts of weight to be saved, but just a cursory look leads me to believe there will be a lot of bumpsteer with the width of those racks.
A racing rack and pinion could get you correct width, but there's a lot of fabrication involved in something like that too.
Old Aug 1, 2013 | 02:42 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Re: spohn Pinto R&P
I don't know who spohn uses for their rack and pinion, the one I have is from Unisteer, they shorten the rack for our Camaro's. If you are getting a k-Member at the same time you can get the rack mounts put on it, you will need a bump steer kit and will have to get a steering shaft. If you go to PA racing, they have a nice steering shaft kit for our cars.
Was not compilcated to do, could easily be done in a day, that is how long it took me
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
luvofjah
Sep 26, 2015 08:28 PM
