Steering wheel spins on shaft
Old Jul 29, 2013 | 02:21 PM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
My fuel pump went out, so we were pushing my car today. I went to turn the wheels and it steering wheel turned but the wheels did not. It is not completely loose, and you can turn the wheels with it when the power steering pump is engaged. What causes this and how do I fix it? I do have a GT Grant wheel on there, but it has been on there for a couple years now with no issues. Any help or suggestions is greatly appreciated.
Old Jul 29, 2013 | 02:34 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Steering wheel spins on shaft
Wow, Thats scary. Plull the wheel sounds like the steering wheel hub adapter splines are stripped or the wrong adapter was used on installation.
Old Jul 29, 2013 | 02:44 PM
manolis1969's Avatar
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
you have no issues at all when the motor is running? take a look to see if the steering shaft (close to the gearbox) is turning when u turn the wheel..and follow it through to see if it turns the pitman arm
Old Jul 29, 2013 | 02:45 PM
rdhanded2's Avatar
Top Answer: 1
so possible replacing the wheel or the install kit could correct the issue?
Old Jul 29, 2013 | 02:48 PM
its possible it is the splines that stripped..but an easier thing to check at the moment would be to turn the steering wheel and see what happens to the shaft at the gear box as u do...
Old Jul 29, 2013 | 02:49 PM
rdhanded2's Avatar
Top Answer: 1
Will do. Can't get to it until tomorrow but i will check it out. Thanks
SlowAZ28
Aug 31, 2015 07:56 PM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
