Ordered founders LCA Relocation bracket and didnt work for the 9 inch I'm running. Due to the shock mount being different than stock 10bolt. Looking for suggestions on what to order that will work. Not sure what type of rear end it is (ex ford, moser, etc...) The difference that wouldn't allow me to use the brackets are the shock mount tabs and LCA bracket are seperate pieces on the 9 inch as opposed to stock it's a combined piece. Hope that makes sense. Thanks.
I dont belien there is a bolt on solution for you, just have the ones you have now welded on.
Quote:
The bolt-on ones are for the stock 10 bolt rears. The ones for 9" aftermarket rears are different and need welded in.Originally Posted by rwerk91
Ordered founders LCA Relocation bracket and didnt work for the 9 inch I'm running. Due to the shock mount being different than stock 10bolt. Looking for suggestions on what to order that will work. Not sure what type of rear end it is (ex ford, moser, etc...) The difference that wouldn't allow me to use the brackets are the shock mount tabs and LCA bracket are seperate pieces on the 9 inch as opposed to stock it's a combined piece. Hope that makes sense. Thanks. Senior Member
Same here. Founders don't mention this fact when ordering them. I dont want to send them back as the shipping wouldn't be worth it
