Adj. Torque Arm
Old Sep 3, 2013 | 10:32 AM
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
Adj. Torque Arm
I just finished installing it now I need to set it. Can anyone just quickly tell me how to set it up for street driving? Also the damn driveshaft loop hangs real low, Infact it is the lowest thing now. Is there anything I can do saving cutting it off.
How do I set the torque arm?
How should I set my panhard bar?
Old Sep 4, 2013 | 09:31 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Adj. Torque Arm
Who made the Torque Arm? Mine was Spoon and it came with instructions for setting it up.
Old Sep 5, 2013 | 11:43 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: Adj. Torque Arm
Can you take a pic of your driveshaft loop? Curious to see how low it sits.. Also which company TQ arm is it?
Old Sep 5, 2013 | 06:28 PM
gregl316's Avatar
Re: Adj. Torque Arm
It's a Spohn. I got it off Ebay from Camaro Hawks. It didn't come with the instructions or the pinion angle tool that it says it should from Spohn if bought from them directly.
I'll try to get a pic of the loop. But it is now the lowest thing on my car.
Old Sep 5, 2013 | 07:21 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Re: Adj. Torque Arm
http://www.spohn.net/support/questio...n+Instructions
Just go to spohn.net and then to their support center and then instructions and then search for your sku. I just guessed yours was this one.
Old Sep 6, 2013 | 02:18 AM
cmccomb's Avatar
Car: 85 sport coupe
Engine: 406 sbc world products 600 HP
Transmission: 700 r4 level 4 PATC 4500 stall
Axle/Gears: Moser 9" 3.70 detroit locker
Re: Adj. Torque Arm
This is what i did ;
cut the drive shaft loop bracket and angle it up and also cut close to the loop it self and re position loop and reweld , notice also i chose to add the two supports behind the original crossmember mounting points for added support.
hope the pictures will help
Attached Thumbnails Adj. Torque Arm-p1010001.jpg   Adj. Torque Arm-p1010003.jpg
Old Sep 6, 2013 | 12:58 PM
gregl316's Avatar
Re: Adj. Torque Arm
I thought about that too. Thanks for the pics I guess I'll have it done when I have the SFC'c welded in.
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
