Nasty squeak? Bushings?
Car: 86 Camaro
Engine: V6
Hey guys,
I have a nasty squeak coming out of my left side rear suspension when I go over a bump. I have pretty much decided I am going to replace the bushings for the sway bar, LCA and panhard.
Can anyone recommend a good place to get a rear suspension rebuild kit?
Thanks!!
Thanks!!
Re: Nasty squeak? Bushings?
Not much sense necessarily in a "kit".
Get Moog CC635 springs; shocks of your choice; Lakewood LCAs & PHB (check the board sponsors first though, some one of them may have something worth looking at); and Energy Suspension sway bar parts.
You won't even recognize that it's the same car, back there.
Car: 86 Camaro
Engine: V6
Thanks for the quick response!
Interesting, I would like to go that route, a few paychecks later lol, not too concerned with performance right now just trying to get the squeak out. Plus I would think that putting all that into my rear is going to make the front feel a little off
Also all I can seem to find is Polyurethane bushings and I have been advised to go with rubber if I can find them, any thoughts on that??
At the moment I would plan on buying:
Sway bar bushings:
http://www.hawksthirdgenparts.com/pr...-Complete.html
Panhard:
http://www.energysuspensionparts.com...FWFBQgod9xUAfA
LCA:
http://www.partsgeek.com/catalog/198...m_bushing.html
Sway bar bushings:
Panhard:
LCA:
I would not mess with rubber.
All my cars have poly sway bar parts. Every one, including my wife's and daughter's.
Car: 86 Camaro
Engine: V6
Fair enough, I am going to lubricate the hell out of the suspension this weekend and see if that does me any good, then I will work on the replacement.
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Worst suspension squeek I ever heard was from my neighbors mustang. It was a BAD lower ball joint and a few days later the ball popped out of the joint as he entered his driveway. At speed, it probably would have caused an accident. Check those.
camaro1185
Oct 26, 2015 06:51 AM
