Gear ratio question
Old Sep 27, 2013 | 12:54 PM
TreDeClaw's Avatar
Car: 1983 TA WS6
Engine: 357 (5.7L)
Gear ratio question
So I was reading the tech article on this site about gear ratios, but I still don't truly understand.
I know that a 3.73 is better then a 2.7(fill in the blank) but why.
At redline, which gear is faster, better, and why?
I have 3.23 gears.
Old Sep 27, 2013 | 04:58 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Gear ratio question
The higher the ratio is numerically(3.73 vs 2.7x), the more engine torque is multiplied at the rear axle. The result is faster acceleration, but the engine will run at higher RPM's on the highway and use more fuel overall. The lower the ratio is numerically, the slower it will accelerate. But your engine will run at lower RPM's on the highway, and use less fuel. All of this is somewhat defendant on your engine and transmission however. If you have a weaker engine(like a 4 cylinder for example) it won't have the power to take advantage of the higher gear ratio's ability to accelerate faster. The transmission also changes gear ratios to shift gears, so you can end up having to shift sooner or hold a gear longer depending on its ratios.
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
