coilover pics? anyone with coilovers, post them up
Old Oct 2, 2013 | 09:44 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
looking around the site, you dont see too many guys with coilovers, and i am currently build\ing my setup and once all the pieces are finished, i will post pics also... so please, share what your running
Old Oct 3, 2013 | 10:23 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Re: coilover pics? anyone with coilovers, post them up
Front, rear or both
Old Oct 4, 2013 | 01:13 AM
morrow's Avatar
Car: 92 Camaro Rs.R
both, anything, lol
Old Oct 5, 2013 | 09:12 PM
572_Rat's Avatar
Sorry the only picture I have is when the were mocking up my back half but it will give you an idea
Old Oct 7, 2013 | 10:45 PM
morrow's Avatar
Car: 92 Camaro Rs.R
looks beefy, what spring are you using
Old Oct 9, 2013 | 11:01 PM
572_Rat's Avatar
These are strange engineering coil over, can't remember the spring rate, but they came recommended from strange for the car
Old Jun 23, 2016 | 06:29 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Old Jun 23, 2016 | 09:21 PM
chad pickens's Avatar
Old Jun 23, 2016 | 09:27 PM
Old Jun 23, 2016 | 10:04 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
My personal opinion is to stay away from front coil-overs and keep the spring weight on the a-arms and k-member.
If you are going to go with coil-over fronts, do put the plate in below to spread the weight across the tower. I did this even though I have the Koni yellow struts:
I used RideTech on the rear, inverted- very happy w/my choice!
Manufacturer/ Model #/ Range/ Collapsed/ Extended/ Standard Spring Rate/ Spring Height
RideTech/ HQ6110/ 14"/ 11.34"/ 16.5"/ #200/ 12"
#850 front w/weight jacks with 36mm sway bar; and #250 rear on the 12 bolt with a 19mm sway bar. Plates up in the back, as well.
Attached Thumbnails coilover pics? anyone with coilovers, post them up-dsc01119.jpg   coilover pics? anyone with coilovers, post them up-dsc01120.jpg
Old Jun 24, 2016 | 12:59 AM
morrow's Avatar
Car: 92 Camaro Rs.R
Awesome. Great setup. I can't use the spring buckets due tie my control arms being custom made and stretched 3 inches
Old Jun 24, 2016 | 01:00 AM
morrow's Avatar
Car: 92 Camaro Rs.R
totally agree on the plates by the way
Old Jun 24, 2016 | 01:15 AM
morrow's Avatar
Car: 92 Camaro Rs.R
My car is wide body. And the suspension width is stretched by 6 inches over all
Old Jun 24, 2016 | 07:23 AM
Dreambird's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 6.0l LQ4
Axle/Gears: 3.73 True Trac
Viking rear coilovers and front struts 850lb front 34mm bar 140-250 progressive rear soon to be 175-350 rear bar 24mm soon to be 19 or 21mm
Old Jun 24, 2016 | 08:31 AM
morrow's Avatar
Car: 92 Camaro Rs.R
your running 850 fronts?! On a coil over?! How stiff is it.. I bet it's super stif
Old Jun 24, 2016 | 09:16 AM
Dreambird's Avatar
Engine: 6.0l LQ4
850 front non-coilover and 140-250 rear progressive on coilovers
Old Jun 24, 2016 | 09:35 AM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
With the 480Le, you could go #275 on back. Do you have an aftermarket rear with that? Lowered the axle-side panhard?
Old Jun 24, 2016 | 09:41 AM
Dreambird's Avatar
Engine: 6.0l LQ4
I was going to try some 175-350 progressives and reduce the rear bar to a 19 or 21, but I will keep the 275's in mind. I've been working with SlickTrackGod on the setup it works well now trying to fine tune it. it has a Jegs axle side lowering mount down one hole from stock
Old Jun 24, 2016 | 09:53 AM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
morrow i was gonna follow you oon instagram but now cant find you lol
Old Jun 24, 2016 | 05:27 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Dean knows his stuff .. Him and I worked together on a few things when I designed the suspension in my third gen .. He's a good friend of mine .. Defiantly listen to what he has to say
Old Jun 24, 2016 | 05:28 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Morrow_motorsports is my instagram
Old Jun 24, 2016 | 06:32 PM
Dreambird's Avatar
Engine: 6.0l LQ4
He sure does! I'm not sure where I'd be with my setup without him, probably completely lost. I've learned enough from him now that I am starting to make adjustments on my own.
Old Jun 24, 2016 | 06:55 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Awesome! What's your setup
Old Jun 24, 2016 | 08:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Morrow, are you going to have any suspension travel withe the coilover mounted directly to the strut plate like that or are the strut plates spaced off the tower?
Old Jun 24, 2016 | 08:27 PM
Dreambird's Avatar
Engine: 6.0l LQ4
850LB front springs with Viking DA struts and swivel weight jacks, 34mm front bar, global west front control arm bushings,gun-drilled and braced front control arms, 1" ext ball joints, LS1 brakes PWR Stop rotors and pads, strut brace and wonder bar, bump steer adj rod ends, UMI sub-frames stitch welded, Unbalanced Eng torque arm, aluminum rear control arms w/rod ends and roto joints, control arm relocation brackets, Viking DA coil overs w/140-250 progressive springs soon to be 175-350, 24mm rear bar soon to be 21 or 19mm, aluminum panhard bar and Jegs axle side bracket, 4th gen rear. LQ4 swap w/4L80E 3.23 gears. That's about it
Old Jun 24, 2016 | 09:33 PM
morrow's Avatar
Car: 92 Camaro Rs.R
This setup has massive wheel travel. Keep in mind the entire front suspension was built from scratch.. Everything , coo lovers inside and out. Lower control arms are 3 inches wider on each side, upper chamber plate it built specifically for these Struts only, they use a 7/8 unibal in the top, the coil over length is shorter that what all the others struts are in order to have the strut stroke in the middle of the stroke so it has equal up and down travel setting the valves in side the shock it's perfect level. So over all. The strut is shorter over all . Which also helps keep the spring out of the strut tower enabling much more alignment adjustment room at the camber plate. Idk if I'm making sense though lol if I'm not making sense tell me
Old Jun 24, 2016 | 09:43 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Sounds like a good stout combo
Old Jun 24, 2016 | 10:01 PM
Dreambird's Avatar
Engine: 6.0l LQ4
Thanks it runs pretty good , now I just need to catch-up with it
https://www.thirdgen.org/forums/imag...es/driving.gif
Old Jun 24, 2016 | 11:06 PM
morrow's Avatar
Car: 92 Camaro Rs.R
If you ever need advice about anything regarding setup don't hesitate to ask. I was busy earlier when I was explains my front end so I was typing in sperts lol so I'm not sure if I was making sense lol
Old Jun 25, 2016 | 02:45 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Old Jun 25, 2016 | 09:48 AM
SlickTrackGod's Avatar
On Probation
Originally Posted by articwhiteZ
Are you planning to hang the ladder bars on shackles?
Old Jun 25, 2016 | 11:18 AM
car was set up 25 years ago. with this ford setup. just did the coil over update.and going over everything. upgrading and cleaning. as it set for over 10 years. locked away. they have a cross member they bolt to. that is all part of the subframe now,
better shot...over 10 years of dust from sitting
doors open for the first time in over 10 years....almost like a barn find. every thing is getting updated. it was fun in the 90s.
Old Jun 25, 2016 | 08:15 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Looks kinda like the nascar trailer arm idea
Old Jun 7, 2021 | 12:59 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I know this is an old thread, but did anyone have any clearance problems with the coil spring touching the strut hole?
Old Jun 7, 2021 | 01:45 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
No, but i've had them rub on the 'frame' or hump over the k-member. Check for full steering lock to lock. Rubbing on that area would tend to push the spring outward.
Old Jun 7, 2021 | 10:21 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
No problems with clearance beside the frame.
I can turn the wheels lock to lock too.
Just if the spring compresses, it will hit that area.
Talked to Racecraft (have their caster/camber plates and drop spindle) and they said to grind and clearance that area.
Time to get the angle grinder out...
Old Aug 23, 2021 | 10:26 PM
Beeman's Avatar
How did it work out clearanceing for the springs? I asked about your motor plates on the other thread, along with the K member I plan on putting coilovers on the front. I have the adjuster sleeves for the bottom but for the top I have plates that would go under the strut bearings and the springs sit right on the plates with a nylon washer. What do you have at the top of the spring?
Old Aug 23, 2021 | 10:55 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
The clearancing did the trick.
At the top of the spring?
Thrust bearings and washers
Old Aug 23, 2021 | 11:03 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
Front
Rear
Right Front
This is my take on coil-overs on a 3rd Gen.
Old Aug 24, 2021 | 06:51 AM
83 Crossfire TA's Avatar
Huh, you have them in bed with you with a bottle of wine, I think you might need to consider getting some professional help.
Originally Posted by soloc4
Front
Rear
Right Front
LOL, that's your take on a whole new suspension on a 3rd gen...
Old Oct 12, 2023 | 01:16 PM
Tombowman89's Avatar
Car: 88 Iroc
Engine: 388 Vortec Pro-Flo 4 Small Block
Axle/Gears: 3.77 to 1
So the only thing I can’t show yet is the stuff I haven’t gotten yet. I’m waiting on some Panhard bar lowering brackets because of how much body drop I have.
These are the things I figured out as I went along
Old Oct 12, 2023 | 07:39 PM
  #42
Dueling73s's Avatar
Car: 73RS, 85 Iroc, 11 GT
Engine: 383FI, 406 FI, 5.0
Transmission: TKX, TKO600
Axle/Gears: 10 Bolt 3.73s, Strange 12 bolt 3.73
Looks like a nice set-up 89! How does the Viking rear coilover set-up mount up in the rear spring pocket? Is there a reinforcement plate or what?
Old Oct 12, 2023 | 07:56 PM
  #43
Car: 88 Iroc
Basically the coil over goes into the stock shock location with the two adapter brackets that are black in color. The stock spring pockets are no longer used.
Old Oct 13, 2023 | 07:20 AM
  #44
Dueling73s's Avatar
Thanks for the Summit pic. So did you weld in the upper mount?
Old Oct 13, 2023 | 08:42 AM
  #45
Car: 88 Iroc
I didn’t weld any of the brackets, the instructions didn’t state to do so, plus I hate grinding off powder coated parts to then only just spray paint bomb them lol. But welding them would probably be the best thing for a racing application plus the sanctioning body would more than likely require it. But that’s just speculation, heck some may not even allow you to use parts like these idk. Rules schmools
Old Oct 13, 2023 | 09:04 AM
  #46
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
I did the Spohn kit, same style of plate, doesn't require welding
Old Feb 8, 2024 | 06:57 PM
  #47
Beeman's Avatar
Late to the party but here's pics of my fronts. No idea what brand the upper spring seats are but I had to use the stock strut bearings with them as they fit into the bottom of them. I'd like to use my aftermarket C-C plates but to use them I need an upper spring cap that will fit a factory style strut with a 1: shaft. Anyone got a part # of the spring cap? I'd probably have to make a spacer to get the spring below the wheel well so I could get more caster.
Old Feb 9, 2024 | 06:52 PM
  #48
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Tom good looking setup u got there.
How much noticable difference is it from stock.
Old Feb 10, 2024 | 11:59 AM
  #49
Beeman's Avatar
@morrow Don't know if you're still on this much but I'd like to know what upper spring hat and spacer you show on your strut.
I need a spring hat that has a 1" hole for a 2.5"ID diameter spring. Then I could use my UMI caster camber plates. Anyone have a part # or source for them? I can make the spacer if need be.
ROCFATHER
Apr 8, 2008 12:25 AM
JucinGTA
Jul 18, 2002 09:41 PM
