Rear end sitting low?
Old Oct 9, 2013 | 10:18 PM
projectRS92's Avatar
Car: 92 camaro RS
Engine: 305 TBI
is there a better spring i can get not stock.. thats a little heavy duty and will sit my rear end a little higher then it is or a better Shock Absorber i should get to. some thing that will let stiffen up the rear
Old Oct 10, 2013 | 01:53 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Re: Rear end sitting low?
If the rears are original, just going with a new factory replacement is going to raise it back up. Moog makes a good one that lots of people are using.
Same can be said for the shock. If they are original, replace them. KYB makes a decent factory replacement or you can step up to some of the other higher end brands like Bilstein or Koni. All depends on how much your wallet can take.
Old Oct 10, 2013 | 04:12 PM
Car: 92 camaro RS
Engine: 305 TBI
thats what i just put in.. trying to found bigger springs or more heavy duty
Old Oct 14, 2013 | 09:24 PM
myroc86's Avatar
Car: 86 Camaro
Engine: 350 LT1
Did you put the insulators back in when you swapped springs? Not knocking your abilities but I have seen it happen to a few on here and other forums.
Posted from Thirdgen.org App for Android
Old Oct 14, 2013 | 10:43 PM
midnightfirews6's Avatar
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
Do you mean that it's sitting low compared to factory, or it's just lower than you would like? Moog springs and factory isolators will have it sitting pretty high and it should be as high if not higher than it was when it was brand spanking new. 4th gen rear isolators are thicker and can raise it even higher than stock but I really don't recommend it since that sort of stance is associated with and perpetuates very negative stereotypes about fbodies...
Old Oct 15, 2013 | 10:16 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
If the rear looks like it is sitting low then I would try a set of 4th gen isolators. I put them in my car and it helped level out the stance. It now has a very gradual rake to it so that it sits nice.
Old Oct 15, 2013 | 10:40 PM
Car: 92 camaro RS
Engine: 305 TBI
were can i found 4th gen isolators and thanks for the help
Old Oct 15, 2013 | 11:28 PM
I got mine at the dealership a few years ago. The guy asked me what year so I just said '98 for whatever reason. Fit perfectly and made the stance perfect. If you go to my profile I think there is a link to my CarDomain or FOAT page that has pics.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
novaderrik
Aug 10, 2015 12:44 PM
