Founders Performance New and Improved Camber Plates
Old Nov 8, 2013 | 01:07 PM
FoundersPerf's Avatar
Former Sponsor
We just wanted to share with everyone that we just improved our caster/camber plates. We are now shipping all of our camber plates with a 1 piece, chrome-moly, forged bearing cup. No more welds on the bearing cups.
Old Nov 8, 2013 | 02:14 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Re: Founders Performance New and Improved Camber Plates
Was there something happening with the old ones that caused you to switch designs? I have a the older style on my car but it still isnt on the road yet. It will be mainly used for road racing/auto x, should I switch to the new style?
Old Nov 8, 2013 | 02:20 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Those look nice. Better then most the other ones out there.
Still wondering why nobody has redid the aluminum ones like I have. (alloy eng. ones)
Old Nov 8, 2013 | 02:50 PM
Former Sponsor
No, nothing wrong with the others. We are just always trying to figure out ways to make better products than anyone else.
Old Nov 8, 2013 | 07:08 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
a little confused... are these used in conjunction with the main plate with the slots for adjustment?
Old Nov 8, 2013 | 07:40 PM
Former Sponsor
Yes these are the bearing mounts that go into the main camber plate.
Old Nov 8, 2013 | 09:29 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
How much does this add to this current price?
Old Nov 9, 2013 | 02:45 PM
Former Sponsor
The price is staying the same.
Old Nov 9, 2013 | 02:53 PM
Well you can't beat that lol. When the funds allow I'm buying 2 sets for both of my cars.
Old Nov 9, 2013 | 04:00 PM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
The ones I got 2 months ago don't look like they're welded.
Old Nov 9, 2013 | 04:29 PM
Former Sponsor
If they are black they are welded. We have been shipping these for a couple Month's.
Old Nov 9, 2013 | 04:31 PM
actarnoff's Avatar
Engine: 355 TPI
Yeah the ones on my car look like these; top notch by the way.
Old Nov 11, 2013 | 04:02 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
How well will they work with a coilover kit?
Old Nov 12, 2013 | 11:13 AM
Former Sponsor
They are plenty strong for coilovers.
Old Nov 22, 2013 | 08:56 PM
actarnoff's Avatar
Engine: 355 TPI
I've put these to the test already on a tough autox course; they hold up just fine.
Old Nov 23, 2013 | 05:30 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
So what's the price to upgrade to those? Already have the prior design.
Old Nov 25, 2013 | 02:31 PM
Former Sponsor
If you already have the prior design I wouldn't waste your money on switching to these. The old ones are plenty strong just more labor for us to build them.
Old Nov 27, 2013 | 03:57 PM
bwmcam's Avatar
Car: 1987 IROC Camaro T-Tops Rule!
Transmission: 700r4 Pro Built / 2600 vigilante tc
Do you have a pic of the other side?
Old Dec 5, 2013 | 01:41 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Truth here. I run coil overs and I beat the **** out of my car. I love my camber plates.
Old Dec 5, 2013 | 03:41 PM
bwmcam's Avatar
What is the design for holding the spherical end in? UMI uses a snap ring. What do these use? Thanks!
Old Dec 6, 2013 | 12:05 PM
Former Sponsor
These are press fit bearings with a high strength anaerobic sleeve retaining compound and then backed up with spiral lock.
Old Jan 12, 2014 | 08:30 AM
TTA976's Avatar
Are these still available? Don't see them on your homepage.
Joe
Old Jan 12, 2014 | 09:25 AM
Copperhead's Avatar
Do they increase camber over the stock mounts? Or just make it stronger and easier to set?
Old Jan 12, 2014 | 11:57 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Joe
These?
http://www.foundersperformance.com/c...-Strut-Mounts/
Old Jan 12, 2014 | 02:53 PM
TTA976's Avatar
Originally Posted by Scorpner
You got it, thank you. Yep, I have that page saved but didn't see the additional pic on the right when I looked. Dang, that's a great price too.
Joe
Old Jan 12, 2014 | 04:57 PM
SlickTrackGod's Avatar
On Probation
>>>So when the glue and the snap ring eventually fail, you loose your wheel assembly.
Never on my car. I want a top insert bearing that would never come out the bottom and loose a critical suspension mount link.
Old Jan 12, 2014 | 05:01 PM
On Probation
Spohn has made them for several years now out of steel. The aluminum ones fail over time and the bearing comes loose. due to metal fatigue around the snap ring. The steel ones have yet to show any failure signed with many years testing. Hunter has a great design and Spohn perfected the one weakness with steel units rather than aluminum.
Old Jan 12, 2014 | 06:24 PM
TTA976's Avatar
Cool. Thanks
Old Jan 13, 2014 | 02:41 PM
Former Sponsor
Yes these give you greater adjustment with both camber and caster.
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
rb85TA
26
Sep 14, 2015 10:29 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
