eibach sportlines
eibach sportlines
anyone know if sportlines drop out of seat area when you rack the vehicle meaning you have to jack the axle housing up and seat them before you lower the car onto the ground also anyone running these with koni yellows any info on for ride quality
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Re: eibach sportlines
I had those on my car with the Koni yellows. It came that way from the past owner. The ride was very firm, I liked it. I had to change them out as the ride height was too low for Pgh streets.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
The rears will come loose when you drop the axle all the way, at least mine did when I still had them
Car: 1991 camaro Z28
Engine: 5.7 350 TPI with a performance chip
I currently have that combination. The rears fell out of mine when I jacked it up. It's a firm ride.
Car: 83Z28 HO
Transmission: G Force 5 speed
It's not too uncommon for shorter springs than stock are loose in the perch when you jack the car up and let the rear hang....heck, even most stock springs will do that.
But if they are installed correctly, they'll settle right back in when you drop the car back down.
