How to set up my rear suspension
Old Jan 28, 2014 | 02:09 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
K I have a 91 bird .... My ? Is how do I set up my rear suspension for good launch ? I have a BMR trans crossmember so I can move the torque arm up or down but the TA is not adjustable ... I also have adjustable control arms and adjustable panhard .... The car is at stock ride height ... And I have 4:10 gears with T-5 trans ... I know the panhard is easy just center the axle but what about the TA and control arms ? What happens when il engthen or shorten the control arms ?.... And what happens when I lower or raise theTA ? Thanks for any help !! ..... I had the torque arm 2
Holes from all the way down n moved it up 2 holes which is 1 from all the way up and it feels like it is better than it was as far as hookin up and before it just kinda felt like it was all in a bind with it that low ... And had a slight vibration at times which seems to b gone now after raising it .... What is the optimum angle from rear end to engine in degrees ? I have a magnetic degree finder ... Engine is in stock location and I've lost about 200 lbs off front end sovereignty stock . And I have SFC's if that matters
Old Jan 28, 2014 | 03:30 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Re: How to set up my rear suspension
Do you have lower control arm relocation brackets? They will help your hook up. You could put them to the lowest setting at the track. Should give you great hookup. Don't think you should use that setting for general driving. Makes handling on the brakes with ANY steering very freaky- ( I tried it once- set it right back after a test drive ;-)
Also, I think the steeper the angle of the Torque Arm, the better the forward bite- offset by looser handling on the brakes.
Old Jan 28, 2014 | 06:06 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
The adjustable lower control arms are also for centering the rear end. Many of these cas have body's that are not as straight as they were leaving the factory due to an array of reasons. Some people have reaerends that might not have the strictest QC. For the LCA angle you at least want to be sure that the through bolt on the rear end side is lower than the through bolt on the body side to help prevent wheel hop. If it is stock height you may be able to go without it but if it is lowered they become a must.
Old Jan 28, 2014 | 08:19 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I think having the axle side mount lower than the chassis side mount leads to oversteer in and out of corners. If the axle side mount is higher, you get understeer...
My car is pretty tail happy at the autocross and Im starting to think this is why. I dont really dislike it. It's controllable and makes it a little more responsive, but it will go around on me. (See the sig?) So I have to be a little more careful. Would probably be faster with the LCAs closer to level... or higher.
I need to experiment with this...
Old Jan 28, 2014 | 09:35 PM
Tibo's Avatar
Car: 1991 Z28 Vert
I doubt you would be faster unless it was because the turn was too tight for our turn radius and it was whip the rear end around or hit cones for a time penalty. Keeping the rear end of the LCA lower helps to keep the wheels planted. If you just wanted to make one higher to give less traction just get a peg leg differential.
Old Jan 28, 2014 | 09:43 PM
Car: 1992 Camaro RS
I wouldnt put it back to the stock hole to decrease traction, I would do it to increase stability. There's a fine line here... I think the answer is to lower the car more so that they are level.
Keeping the rear of hte LCA lower helps keep the wheels planted from a dig. Not in a corner. in a corner, if the LCA's are both angled down and you turn, the outside LCA is going to approach being completely level, while the inside LCA will become more angled as the chassis lifts above the axle with body roll. That means the axle is basically pointing in the direction of the cars rotation. I think this translates into a very responsive car on corner entry, but it can create traction and stability issues.
If, for example, the opposite is the case, both are angled slightly upwards, the axle will steer into the corner and slightly prevent the car from rotating. Maybe slower, but it creates understeer as the body rolls, and as you apply power it points the car in the direction you want to go, not in the direction you WERE going, allowing you to get on the power sooner and control the car better.
I am NO guru in this, it's just been something I've been mulling over in my head lately ever since I heard Dean talking about axle steer, and since I've got my LCARBs and played around with rod end bushings vs poly bushings... and Im starting to notice some things and make connections. I'll need to experiment more to see if it really makes a difference, and how much it would be. Im kind of surprised no one else talks about it much, to be honest, maybe it's a non issue?
Originally Posted by TEDSgrad
Here's some Dean text before he and Pablo went off the reservation and got the thread locked ("The Grip"):
Roll induced understeer is simply put= rear wheel steer. So lets just go over basics.
The rear wheels on a solid axle can change direction based on the arch of the LCA attachment arms. When the arms are out at starightest point (parallel to the ground) they are at their longest geometry.
When both lcas are at the same angle thier is no thrust angle of the axle (this is ideal with a proper alignment, given the proper aftermarker adjustments with adjustable LCA's)
However, when the car body rolls, the rear swaybar will try and keep the LCA's the same but they still differ. If you can keep the LCA geomerty on the inside wheel to articlulate to where the INSIDE LCA stays parallel to the ground while the OUTER LCA archs upward towards in geometry from the chassis mount to the axle, this parallel distance between the mount and the axle vertical centerline will decrease as the axle on that side will be pulled forward more than the other side of the axle. This causes rear steer.
Now with rear steer, the rear wheel pointing towards the corner of turning will cause the car not to rotate as the car leans to set. It wants to hold the back of the car towards the inside of the corner. Roll induced oversteer would throw the rear of the car outward and would make it harder to recover- and ths harder to retrieve the car back to straight tracking becuase of increased momentum of the chassis. So whith that said, I hope you can understand how roll UNDERsteer will resist polar motion and allow the car to hold the rearend tight, as well as help bring the rear end back staight after steadystate and going into corner exit.
The added benefit of this is the roll understeer makes a little more slip angle beause of the rear wheel steering- just like how front wheel steering does this, we are matching the rear a little closer to the front rather than the rear being neutral with only load slip angle. The rear now has load and steering angle just as the front does so the footprints are much closer if veiwed from under the road.
Please read this- It will talk about slip angles and slide angles. Remember also that the inside of the car is better weighted when the overall car gets to set mid corner chassis roll. To best example this, lets say if most cars did 100% outside and 60% inside, mine was doing 100% outside and 75% inside
http://www.mgf.ultimatemg.com/group2...slip_angle.htm
Old Jan 28, 2014 | 10:10 PM
SlickTrackGod's Avatar
On Probation
Since all cars have different amounts of grip AND torque, there is no 1-for-all setting for suspension setup on a drag launch.
When it comes to LCA relocation brackets, the best thing I can suggest mount he LCA into them on a hole that makes the LCA parallel to the ground and try the car. If wheel hop persists, then move the rear mount position down one hole and tray again. I would only do this twice at most, teally onc eis enough to suggest that the car has too much grip/power for that spring rate and the arms are inverting upon massive thrust squat.
Two things can be done to troubleshoot this
1) the very bes tthing you can do is insert rubber 'O'rings onto the rear shock shafts (zip ties work great instead for non removal of the shocks). Once the car is on the ground at static ride height- simply crawl under there and ground the Oring or ziptie down onto the shock body. After a test launch, climb under there and measure with a tape the distance the oring is now above the shock body- heance your suspension travel/or squat under launch. This travel can then be masured to see just how much the LCA's are possibly inverting under traction load. If the movement is excessive then stiffer springs are in order. The arms shold remain close to parallel under max thrust for best forward propelling motion of the axle against the chassis.
Lowering the LCA to the lowest setting of a relocation bracket is very dangerous if it makes the rear mount more than 1" lower then the front under stagnant position. THis should never be down because the axis will create rear steer towards the outside of the corner when the car is loaded into a turn=- a very very bad thing.
2) Videotape the car at launch. Watchiong tape footage and measuring the wheel travel into the fender will also show what the car is doing both on rear squat as well as front lift to see how the entire chassis reacts.
EDIT: I see I was quoted above just as I was posting. I am Dean for those who may not know.
Old Jan 28, 2014 | 10:35 PM
Tibo's Avatar
Car: 1991 Z28 Vert
As long as the vehicle in question has a suspension system, you are going to have body roll on any and every turn. Yes that body roll will result in an acute change to the degree of the LCAs. However, that degree of change will depend upon the suspension of the vehicle, how settled the chasis is before and during the turn, how sharp the turn is and how fast you are going. It sounds like you are advocating changing the LCA angles (so that they are parallel or the rear is higher) in order to prepare for the corners/turns wherein you will be traveling the fastest and turning the most/sharpest. In turn (no pun intended) this will will then hurt you on any low speed or broad turns and all straight-a-way sections. Not to mention 99% of the driving you will do on the roads.
Old Jan 28, 2014 | 10:38 PM
Car: 1991 firebird
Axle/Gears: 4.10
Thanks a lot guys some good info here ... Right now my LCA's are almost perfectly level ... Which the car is at stock ride height and has
New stock replacement MOOG springs all The way around for a Base model firebird ... And new Monroe shocks n struts all the way around stock replacement stuff again .... And also the WS6 factory sway bars all the way around 36& 19mm ? I believe .... With all new poly links and bushings .... LCA's and panhard have rod ends ..... I really don't get any wheel hop on the street with street tires but idk about drag radials at the track yet ... Haven't had it to the track since several of the suspension upgrades or with the new motor in ... For those of u with LCARB's ... Are They worth it on a stock ride height car ? I guess more adjustability is always a good thing ... Also would a tubular upper panhard brace b worth anything ? Or one of those upper panhard relocation brackets ?
Old Jan 28, 2014 | 10:50 PM
Car: 1991 firebird
Axle/Gears: 4.10
Another thing I noticed is after installing the fat front sway bar and posi rear end the car didn't wanna bring the rear end around like I want it to in a hard corner it wanted to slide the front tires instead .. What causes this ? It seemed the bigger front sway bar caused this ... And was thinking about tuning my front sway at by cutting the spacers down by like 1/8" at a time ..
Old Jan 28, 2014 | 11:02 PM
Car: 1992 Camaro RS
To be clear, Im thinking the best thing to do is to get the rear LCA's completely level, but what Im wondering is since my car is lowered about 1 inch from stock, am I better off with them angled upwards in the factory spot, or downwards in the middle slot on the LCA's? The real solution I think is to just lower the car more to get them level. But in lieu of doing that, surely one of those two options is preferable. As you said, body roll, and therefore axle steer, is inevitable and unavoidable. It does seem to me to be the case that the stock hole will lead to more stable cornering and the middle hole will lead to more responsiveness but looser cornering. I just dont know which is faster.
If you're at stock height I wouldnt bother with them unless you plan to go to the track a lot. The advantages of LCARBs for drag racing are pretty well established. Put stickier tires on it and watch them hold with the LCARBs. The other thing is... do you think you will ever lower the car? If so, you can/will/might use them then.
Old Jan 28, 2014 | 11:20 PM
Tibo's Avatar
Car: 1991 Z28 Vert
To be clear, Im thinking the best thing to do is to get the rear LCA's completely level, but what Im wondering is since my car is lowered about 1 inch from stock, am I better off with them angled upwards in the factory spot, or downwards in the middle slot on the LCA's? The real solution I think is to just lower the car more. But in lieu of doing that, surely one of those two options is preferable. It does seem to me to be the case that the stock hole will lead to more stable cornering and the middle hole will lead to more responsiveness but looser cornering. I just dont know which is faster.
I don't see how having the LCAs at 0* or higher angle like the factory put them at would be the better overall solution. Putting the back end of the arm lower will give far better performance on everything except very sharp and fast turns, and even that is debatable based on if the driver can feel the difference and if so how well you can handle the change.
Old Jan 28, 2014 | 11:24 PM
Car: 1991 firebird
Axle/Gears: 4.10
I definitely am not gonna b lowering the car due to the roads around here ... And yes It will prolly see some pretty serious track time both drag strip and autox if I can find somewhere to autox around here
Old Jan 29, 2014 | 07:46 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
The length of the spacers is not a tuning aid, it just attaches the bar to the suspension. Stock/factory sway bars and the aftermarket replacements are not tunable*. You swap bars (36mm to 34mm to smaller, etc) to get softer rates as you are suggesting.
* Having turnbuckles on one or both ends will give you the ability to preload one side or the other. Which will favor turning right OR left.
Some aftermarket bars are adjustable: Either with multiple holes on the arms or with a sliding clamp (on each side) to lengthen or shorten the effective arm.
Old Jan 29, 2014 | 03:42 PM
Car: 1991 firebird
Axle/Gears: 4.10
Originally Posted by MoJoe
The length of the spacers is not a tuning aid, it just attaches the bar to the suspension. Stock/factory sway bars and the aftermarket replacements are not tunable*. You swap bars (36mm to 34mm to smaller, etc) to get softer rates as you are suggesting. * Having turnbuckles on one or both ends will give you the ability to preload one side or the other. Which will favor turning right OR left. Some aftermarket bars are adjustable: Either with multiple holes on the arms or with a sliding clamp (on each side) to lengthen or shorten the effective arm.
Wow there's some fancy stuff in those links .... I think the only thing I saw there possibly in my budget are the turnbuckles lol .... It just seems to me lengthening or shortening the spacers would do the same thing as lengthening or shortening the turnbuckles .... But I'm def not no suspension guru ...
Old Jan 29, 2014 | 05:06 PM
Car: 1991 firebird
Axle/Gears: 4.10
I have another ? About the adjustable LCA's ... They have rid ends on one end and poly on other end do u think it would help my ride quality to put the rod ends on the rearend instead of on the body ?
Old Jan 29, 2014 | 05:53 PM
On Probation
You are suppose to mount them that way. The rod end on the axle side will allow bind free articulation the poly can not in that location.
Old Jan 29, 2014 | 06:06 PM
Car: 1991 firebird
Axle/Gears: 4.10
I believe some LCARB's are in order even with my car at stock ride height the LCA's are 2.5* angled up towards the rearend ... The engine is @ exactly 0* driveshaft @ 1.5-2* and torque arm @ 3*
Old Jan 29, 2014 | 06:24 PM
Car: 1991 firebird
Axle/Gears: 4.10
That's what I thought but someone told me to put them this way ... So I guess that'll be tomorrow's project ... Do u think it will kill some of the harshness of the road ?
Old Jan 29, 2014 | 06:35 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Yes, those are higher end than "just a bar". A turnbuckle can be added to any bar to provided side-to-side bias.
However, that will still not solve your "too much bar in front" problem.
Old Jan 30, 2014 | 12:45 AM
Car: 1991 firebird
Axle/Gears: 4.10
Hmmm I see ... So how do I keep the fat front sway bar and make it all wrk line it should ? ... I have the matching rear swaybar to go with the 36mm front ... Do what gives ? ... I think the next front suspension component I buy will b some founders strut towers and mabey a ST brace I already have a wonder bar in place ... But all that weight I removed from the front end during the engine rebuild raised the from of the car enough for me to have to use ALL the adjustment available in the stock strut towers to get a flat contact patch .... But this thread is more about the rear of the car and as the front swaybar will b disconnected at the track I don't think that matters much at the moment .. Mabey that will b the next thread lol
Old Jan 30, 2014 | 08:00 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
You want to keep the 36mm front sway bar? Yes, put the matching bar on the rear to balance front / rear rates.
Founders camber plates and STB are independent of the sway bars. They will each improve handling, but do not directly affect each other. If you want to spend the money on the parts, they will be worthwhile.
Weight removed = front end too high... you need shorter springs in front. Either buy shorter springs, or you can cut your existing springsto make them shorter. Start with 1/8 coil. I don't think you want to cut more than 1/2 coil total. Note: cutting the springs will increase the spring rate some / make them stiffer. Do not use a torch to cut them. Keep the springs as cool as possible while cutting. The high temperature will change the spring rate... in a bad way.
Old Jan 30, 2014 | 03:07 PM
Car: 1991 firebird
Axle/Gears: 4.10
You want to keep the 36mm front sway bar? Yes, put the matching bar on the rear to balance front / rear rates. Founders camber plates and STB are independent of the sway bars. They will each improve handling, but do not directly affect each other. If you want to spend the money on the parts, they will be worthwhile. Weight removed = front end too high... you need shorter springs in front. Either buy shorter springs, or you can cut your existing springsto make them shorter. Start with 1/8 coil. I don't think you want to cut more than 1/2 coil total. Note: cutting the springs will increase the spring rate some / make them stiffer. Do not use a torch to cut them. Keep the springs as cool as possible while cutting. The high temperature will change the spring rate... in a bad way.
Thanks ... I do know some stuff lol ... I know not to hear the springs ... And I really don't want them to b any stiffer .. The ride quality is really quite harsh as it is .... And the roads close to my house are absolutely awful in every direction for atleast 2-3 miles .... Ghetto ! ..... What would a softer spring rate do all the way around front and back ? Oh and I was trying to say iDO have the matching rear swaybar already !! ... ... And yes I would like to keep the fat swaybars all the way around as I "thought" it would b an upgrade over the stock base model firebird bars ... ... I also plan on a tubular K member and control arms in the near future so I'll mess with the front springs at that point ..
Old Jan 31, 2014 | 01:28 AM
87 Camaro Dude's Avatar
Car: 1987 Camaro SC
Engine: 2.8L V6
That's because a bigger front bar in relation to the rear will cause understeer. These cars already understeer from the factory and adding a larger front bar without changing the rear will just make it worse. With a 36 front and a 19 rear you're just asking for understeer.
Old Jan 31, 2014 | 04:18 PM
On Probation
So many factors that you are just giving a false blanket statement that is so wrong.
A 36/19 is a very proven setup on a race course based on many given intervals.
You are talking about swaybars like it is the holly grail of handling- it is not. They are 'fine tuning' tools to balance out the last little bit of balance. It is not a major suspension change tool. it is the balance the roll axis in both pitch AND canter. yuou do not metion grip, chassis stiffness, shock damper, springs rates, fornt and rear RC changes, and various other geometry that all come first in tuning before a sway bar size is changes to fit each individual chassis setup.
Case in point- on most 3rd gens, the simple addition of SFC's can mean a 2mm drop in rear swaybar size.
Old Feb 1, 2014 | 01:31 AM
Car: 1991 firebird
Axle/Gears: 4.10
So many factors that you are just giving a false blanket statement that is so wrong. A 36/19 is a very proven setup on a race course based on many given intervals. You are talking about swaybars like it is the holly grail of handling- it is not. They are 'fine tuning' tools to balance out the last little bit of balance. It is not a major suspension change tool. it is the balance the roll axis in both pitch AND canter. yuou do not metion grip, chassis stiffness, shock damper, springs rates, fornt and rear RC changes, and various other geometry that all come first in tuning before a sway bar size is changes to fit each individual chassis setup. Case in point- on most 3rd gens, the simple addition of SFC's can mean a 2mm drop in rear swaybar size.
m
Good info ! ... I jus did instal comp engineering outer SFC's a couple weeks ago that r bolt in type which I bolted in and then welded in also ... But what I'm mostly interested in at this moment is getting it to hook up a little better at the strip ... And if possible get a little better ride quality ... Like I said earlier sum LCS RB are definitely needed seeing as my LCA are angle upward toward the rearend 2degrees even at stock ride height with new (3yeAr old) stock replacement moog springs All the way around which actually lifted the caR prolly an inch over where it was with the old wore out springs .... Right now on the street I can come to a complete stop stick it in SECOND GEAR n dump The clutch at 1500rpm n smoke both tires for as long as i want then grab third n do it all over again ... Or stick it in second gear come to a 20-30 mph roll and stab it n up in smoke they go
Old Feb 3, 2014 | 12:07 AM
Car: 1987 Camaro SC
Engine: 2.8L V6
How is anything I said wrong? He said when he put a larger front sway bar on the car, it started pushing the nose more than before. I told him adding front bar stiffness in relation to the rear will promote under steer, which is what happened to his car. A 36/19 combo with stock spring rates is more than likely going to under steer, and the car in question is proof.
Not once in my post did I even hint at the fact that sway bars are the holy grail of handling. He asked why his car behaved like that after the sway bar swap, I told him that's what a bigger front sway bar will do. There was no need to talk about suspension geometry and roll centers etc etc. We get it, you know how a car suspension system works. No need to ruin another thread by flexing your ego.
Old Feb 3, 2014 | 12:02 PM
On Probation
Just one more person that feels a need to put me down when I corrected misinfo they posted. The quote from you was a "36/19 swaybar combo is just asking for understeer."
You made a blanket statement that is wrong...dude
Let me "flex my ego" (sorry, I had to laugh- I ony help people spend their money wisely).
It would be better for him to keep those bars and make further adjustments to take the understeer out of the car by purchasing things like solid bearing strut mounts, chassis bracing, etc. The 36/19 happens to be a very good setup for road course and really not too bad for agressive street use. a 2 36/21 is a little better for street use, but it all depends ont he overall choice of componants and tires size/brand choices as well as shock damper values.
So rather than tell him buy another such and such swaybar it is far better to not spend money wildly on swaybar choices right now and get the chassis balanced through education and proper part installations- then the car will fallinto the perameters of needing these swaybar sizes that ARE in fact well sorted in testing on autox and roadrace balanced V8 car setups.
How's that for an egotistical response?
Old Feb 9, 2014 | 02:07 PM
Car: 1991 firebird
Axle/Gears: 4.10
Mabey u should change ur name to egotistical track god lol seeing as everyone is hating on ur ego or whatever they think they know
And thanks for info man good stuff ! What would be your next suspension mod if u were in my shoes ? With what Info I have provided
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
E Rod
Aug 28, 2015 05:17 AM
hectre13
Aug 26, 2015 08:17 AM
