2 Point strut tower brace for carb/tbi
Car: 92 RS camaro, 99 Z-24 cavalier
Engine: 5.0L TBI, 2.4L
I've seen pictures of TBI cars using a 2 point stb with open elements. Ive done a ton of searching but cant find anywhere that sells 2 point bars that work with anything other than tpi cars. Was wondering if anyone knows where I may find a 2 point bar that could work for a 92 TBI camaro.
Axle/Gears: 10 Bolt 2.73 Open
Re: 2 Point strut tower brace for carb/tbi
While you would probably not call my research exhaustive, I have been through quite a few sites, and found no strut tower brace for the TBI cars other than the Edelbrock / QA1 design, which is 3 point. Joined: Aug 2006
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Only one is the third 3 pts that edelbrock makes and I think qa1 does now.
Or make your own if you have the ability
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
http://www.bmrsuspension.com/?page=p...&productid=376
http://umiperformance.com/catalog/in...roducts_id=126
http://www.summitracing.com/int/part...t/model/camaro
Any of those will fit. The only thing that makes them TPI specific is the notch in the bar, it allows the plenum to fit under the bar. If you have TBI, and are set on running a open element air cleaner (which IMHO I'd recommend against) honestly I'd go for the 3 point bar instead of a 2 point.
I had been looking at those 3 but wasnt sure they would fit because they were designed for the tpi.
There were a few reasons I wanted a 2 point rather than a 3. I personally like the look of the 2 point much better, I'm a little sceptical about having to drill near the firewall, and I keep seeing some people saying the 3 points cracking windshields although that seems to be more of a 4th gen issue.
But you think those would "technically" work with a 14in open element?
@86TA I have seriously contimplated trying this, but honestly havent tried to make anything like this before.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Okay thats good. If im not mistaken I seen that on another camaro forum. Well I may end up breaking down and getting a 3 point instead.
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
http://www.summitracing.com/parts/ha...t/model/camaro
the one listed on summits site. is not the one in the pic.
its going to be a 3 point. with the 2 arms bolted to the main bar and the fire wall flang... you can always add them if ysa want to..or not.
ebay had a 2 point. looks like polished alum. main bar. $96 shipped. listed as the last 1.. so i just did the buy it now.about 20 min ago..
have been looking at them for a few weeks..
http://www.ebay.com/itm/1992-2002-Ch...-/301067991420
@ ArticwhiteZ what are you refering too when you said"you can always add them if you want to"? The extra bolts thats mount to the fire wall?
I was curious if you could just put a 3 point on the car if you could just attach the bar at the strut towers. Couldnt see it hurting anything.
this is the QA1 Brace below
http://www.ebay.com/itm/QA1-5226-Strut-Tower-Brace-1985-92-Camaro-Firebird-5-0L-5-7L-TPI-/400292368423?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d3348d027&vxp=mtr
You might consider replacing the strut mounts (and eliminating their rubber) with after market versions before adding an STB.
JamesC
JamesC
Ahhh okay. I didnt realize the one from QA1 was 3 seperate bars. I thought it was a single piece. Thanks for that info.
And I may go ahead and change the strut mounts with the bar. That sounds like a good time to go ahead and do it.
Car: '89 Camaro
