articwhiteZ
close
I don't have access to my car right now 40 miles away can somebody measure from strut top to strut top..strut bolts... tell me what that is.
Got some scrap billet aluminum. And want to see if the long scap can be used for a strut tower brace...
If so ill make a few
DynoDave43
close
- Join DateAug 2013
- LocationMICHIGAN
- iTrader Positive Feedback100
- iTrader Feedback Score(11)
- Car1988 Trans Am
- EngineL03
- Transmission700R4
- Axle/Gears10 Bolt 2.73 Open
- Liked:919 Times in 699 Posts
I just took some quick measurement on my car ('88, TBI 305, with air cleaner in the way). I went slightly "up and over" the air cleaner, so these are not perfect, straight line, math data measurements. Perhaps a fraction long, which should help avoid buying a piece too short...think positive.
From the two forward (closest to the radiator/front of car) studs, 39.5" on the inboard (closest to the engine) stud, 50.75" to the outboard (closest to the fenders) stud.
Now go build something!
92RS_Ttop
close
The problem with measuring from any of the strut bolts or the struts themselves is that everyone's measurements will be slightly different since they are meant to be moved to adjust the camber. It would be better to measure from the inside top corner of each strut tower for consistency. Then just add an inch or two to each side to account for your mounting locations.
My engine is out right now, but my measurements won't be the same as yours either since I had to replace the driver's side strut tower due to the PO wrecking the car.
articwhiteZ
close
just needed a ball park.to see if the left over could be used..so 45" is in the middle..should work .
DynoDave43... thank you
DynoDave43
close
- Join DateAug 2013
- LocationMICHIGAN
- Car1988 Trans Am
- EngineL03
- Transmission700R4
You are welcome. Cool username...my first new car was a '91 Camaro RS, Arctic White. I hope you post some photos of what you make.
