moog 5662 springs
Car: 87 Camaro Lt
Axle/Gears: 4th gen 3:42, posi, disc
Re: moog 5662 springs
Yup; they are ALOT shorter than stock ones.
THIMK: your stock ones are weeeeeek; takes relatively few pounds of force to compress them relatively a lot. Your new ones are strong: many pounds of force will compress them only a little. Thus, by the time you install them in your car and put the 2000 lbs or so of force on them that they are permitted to enjoy, your stockers will compress like 5", but your new ones will compress like 2", and will end up at about the same height.
Don't cut them until you know what they do. Kinda hard to put a coil back on.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Delete
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
My ride height with old original springs.
LF 26.8 RF 27.75
My ride height with new Moog 5662 (non-cut)
LF 27.3 RF 27.5
I still scrape the air dam enough. No need to cut them.
LF 26.8 RF 27.75
LF 27.3 RF 27.5
LT1Formula
Oct 8, 2015 08:34 PM
