Splines on steering box.
Old May 16, 2014 | 10:25 AM
1o80b's Avatar
How much spline does the steering box have ? I want to buy a new one becaune mine is goddamn loose.
Will this works ? :
http://www.summitracing.com/int/part...t/model/camaro
Old May 17, 2014 | 03:54 PM
Marc 85Z28's Avatar
Re: Splines on steering box.
You want the 6550. Keep in mind that Cardone reman units are generally worn out pieces of junk with fresh paint. You may need to go through several to get a good unit. You would be better off picking one up from your local Advance Auto because of this, and also because they're $40 cheaper than Summit when ordering online and using promo code TRT41.
Old May 17, 2014 | 05:16 PM
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
I got mine from Rock Auto, I can't remember who made it off the top of my head, but it seems pretty good so far. Cheaper than anywhere else too.
Old May 23, 2014 | 12:28 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
should be 30 spline:
http://www.woodwardsteering.com/imag...l%20joints.pdf
I'd just find the cheapest one you can locally at a parts store (for the warranty/convenience). Make sure you ask for one from a z28/ws6 and adjust it properly:
http://www.monte-list.com/tech/boxmesh.shtml
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Zell1luk
Sep 29, 2015 10:36 AM
Night rider327
Sep 25, 2015 04:19 AM
