92 camaro rear shock mounts squeaking like crazy! HELP!
Old Sep 10, 2014 | 09:52 AM
Roachjr's Avatar
I recently lowered my car with springs and installed yellow Koni struts/shocks all around. They were fine at first but now the rear upper mounts squeak inside the car like crazy. I've tightened them, loosened them, and they still squeak. I sprayed wd-40 between the isolators and the body and that fixed it for about 15 minutes of driving before the squeaking came right back. HOW DO I GET IT TO STOP!?? It's about to drive me crazy.
Old Sep 15, 2014 | 01:54 AM
Dezined's Avatar
Car: 91 Camaro RS - B4C option
Engine: L98 5.7l V8
Transmission: 4 speed auto
Re: 92 camaro rear shock mounts squeaking like crazy! HELP!
I had this same problem, but only on the passenger side. If it is the mount, make sure the rubber bushings are installed right. Top and bottom.
Also consider your lower control arm bushings. I swore up and down it was my upper shock mount squeaking until a friend rode with me to listen. That's when we found out it was the lca. Replaced them with aftermarket from Founders, and now no noise.
Old Sep 15, 2014 | 07:00 AM
I'd suggest looking REAL CLOSE at those "mounts" (holes in the sheet metal), make sure the metal isn't cracked around them. That's how they ALL fail, sooner or later.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
