Extending (or de-copmress) new strut shaft
Old Jan 26, 2015 | 10:22 AM
Sonny_T's Avatar
Car: Transam, 85
Engine: 305 HO, 4bbl Carb, G Engine
Transmission: 5 Speed
Trying to install new strut. Strut shaft came in fully compressed. Mounted it and jacked up LCA...still won't reach to knuckle bolt.
What am I missing.
Old Jan 26, 2015 | 11:02 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Extending (or de-copmress) new strut shaft
Take off the little clip that's holding it compressed for shipping?
Old Jan 26, 2015 | 11:34 AM
SlickTrackGod's Avatar
On Probation
Just don't try to "aim it". It will release too quickly for you to try and aim the strut shaft into position of the strut mount hole. Release the A-arm so you have sufficiant room to release the strut cartridge and then jack it all back up into place carefully.
Old Jan 26, 2015 | 11:44 AM
Sonny_T's Avatar
Car: Transam, 85
There are no clips, nothing obvious holding the shaft....
Old Jan 26, 2015 | 11:57 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Skip To Minute 6:35 In The Vid,It Shows How It's Done.
Old Jan 26, 2015 | 12:14 PM
Sonny_T's Avatar
Car: Transam, 85
Saw the full video. Unfortunately there are no such clip, or rubber band ....nothing that is holding the shaft to the body. It is simply sitting there as fully compress...I tried to pull it....mounted it and tied a heavy load underneath hoping eventually it will extend... none...it remains fully inserted (compressed).
"Monroe 71728"
Old Jan 26, 2015 | 01:17 PM
naf's Avatar
naf
Some struts require that the rod be twisted some to release. Try pushing it in slightly and turning it.
Old Jan 26, 2015 | 02:14 PM
Sonny_T's Avatar
Car: Transam, 85
'naf', turning worked, now it is fully extended. Thanks a lot.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
