Suspension and support for ls2
Car: 1987 camaro
Transmission: 700R4 4 speed automatic
My 87 sport model camaro has all stock suspension and everything all around it. If it were to have an Ls2 pushing around 500 or 600 horsepower, what all would I have to upgrade suspension wise. I would like the suspension would have some extra beef to it, and not have it be able to handle exactly what the car is pushing, so basically I don't want something that is the very minimum of what the car makes. Also it's a t top car, so would I have to put SFC's in it to keep the pillars from breaking??? Also would my factory rear end work, or could it be replaced by a ford 9 bolt or something like that. Thanks!
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Suspension and support for ls2
Slow down lol you won't be breaking any pillars lol
Sfc is always a good upgrade stock or not
I suggest searching more threads
But suspension mods really depend on the use of the car street race car handle
turns go only straight
Shock struts , tires , springs would be the biggest upgrades to look at
Then there's lca and lca relocating bracket camber plates bushing upgrades tq arm
Depending on tires and if your going t56 or auto
Auto are more forgiving on drivetrain and rear end
Kinda need more info on your part budget of your auto or manual tire choice etc
Car: 1987 camaro
Well it's gonna be a street car mostly but I may take it to the track for a couple quarters during the summer. I'm still not sure if I want a stick t56 or a auto. Relatively big tires in the back. The project will be started after I'm out of the Navy so I should have a good chunk of money since all my expenses will be paid for.
Engine: 305 to 350
Axle/Gears: 10 Bolt
Cool I'm in navy also fmf corpsman 11 years
Yea I would settle on tranny because if your going to go t56 a 10 bolt won't last long unless you just cruise but what's the fun in having 500 rwhp
You would need to upgrade to a 12 bolt and or 8.8 hybrid for cheap and or a 9"
But yea shocks struts and tires and then springs ie prokit will be biggest improvements
Especially a 9.5 or 10" wide wheel all around
and other supporting bolt on mods For handling as go on into you project getting good deals on the classified
Going manual is a lot more $$$ to keep reliable than auto
A stalled auto is just as fun as manual and if you go auto at least match converter with cam
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
The only necessary upgrade to your suspension to support 600hp would be a rear, the 10 bolt won't take it at all. I would suggest if you can afford it a 9 inch from Moser, Currie quick performance etc. Otherwise and 8.8 out 2001 up Stang and a lot of fab work.
Engine: 305 to 350
Axle/Gears: 10 Bolt
If he running a auto with street tires tires will get ls pinning before rear end brakes
Drag slicks different storie
But sounds like not going that route and wants a fast cruiser
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
LS2 N/A can make 500 (with h/c/i)- 600 is a stretch w/out power adders or NOS. But a stroker will.
You're going to need a whole new drivetrain: LS2, trans, drive-shaft w/1350 U's, and rear (9", 12 bolt, S60).
THEN you need brakes for that horsepower.
THEN you could start on suspension.
Thank You for your service! If you have all the dough, there's better things to do with it, but we're all addicts, here. Best advice: buy a conversion for pennies on the dollar. If you're dead set on building your car, plan it out in stages and keep driving it as much as possible through all the stages.
Post a pic - need body & paint, too?
A quality used LS2 (stock) with big exhaust and a used trans will get you running - around 375rwhp - so time to figure out your brakes (fronts anyway) - year one; [4k motor/harness/pedal/accessories, 1.2k used trans, 1.5k exhaust big for later power, 1.3k brakes, + LS swap ancillaries = 8k+].
If you don't go crazy, the rear will last a year and you can do the rear brakes with the new rear - year two [3.5k].
Now you attack the suspension, 3k, then rebuild the trans for more power, 3k - year three [ 6k].
Then do the h/c/i to get you 500rwhp [2k]. You still have interior and paint to do - year four [sky's the limit].
If you have all the dough at once, you can save some, but I have not included everything (of course, people will debate my figures), and you still have interior and paint not included. All labor is yours (except trans).
Car: 87 Trans Am
Did the LS swap last summer. I need a 4th gear syncro or fork so it's being rebuilt this spring (was not in the plan) but I'll be upgrading it as I build.
I'll be doing springs, shocks/struts this summer as well.
Over next winter I'm getting 17" wheels so I can fit big brakes up front, and will be doing the rear suspension (LCAs, panhard etc).
And then I'll get an 8.8 with rear discs, maybe next summer.
Then I'll be ready for the planned ~ 450hp at the wheels... I estimate I have another $10,000 to go in to the car (interior is good and it's in paint this week)
Car: 1987 camaro
Car: 1987 camaro
I've heard that mosers are pretty reliable so I'll probably settle in one of those
Car: 1987 camaro
Car: 1987 camaro
Car: 1987 camaro
Paints faded and interior is a little used. Almost 200,000 miles but it's been well maintained its whole life. Rebuilt 305 has around 5,000 miles and everything under the car had been untouched (transmission rear end driveshaft ect.) I plan on getting an iroc hood and iroc ground effects then painting it black and giving it two red stripes. Interior will be swapped from all red to black and gray with some black and red seats. She's a work in progress for sure, and could definitely use some love!
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea I agree do it in stages when you collected everything then do it
My biggest regret is having my car sit for so long lol
Go navy lol you love it I been in 11 years been to Iraq and Afghanistan with the marines etc etc its fun time I originaly joined to be a mechanic but I'm color blind so now I save lives lol fix bodies and cars
Sounds like you got a plan if you ever get station in SoCal hit me up
LT1Formula
Oct 8, 2015 08:34 PM
