how can i tell if my ball joints are going out?
Old Dec 18, 2001 | 04:08 PM
breathment's Avatar
ok, previously i would hear a sound from the front left whenver i was backing up witht he wheels turned to the left, it was sort of a loud pop, and i would also hear this noise when braking (about halfway through braking) and this was a single pop, well today i was heading home from school and i heard the same thing but it sounded like it was happening from the front right, over small changes in the road surface. how can i check to tell if the ball joints are screwed?
Old Dec 18, 2001 | 06:56 PM
TopForm's Avatar
To check lower ball joints, raise the car and support the weight on the lower control arms. Check the play by grabbing the tire at the top and bottom and try to move in/out. If there is any play, you should feel it, but it may help to have someone watching the ball joint itself for actual movement.
Brian
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
