Issue with rear upper spring seat
Old Jul 22, 2015 | 03:00 PM
defaced's Avatar
Car: 1987 Firebird Formula
Engine: 355
Axle/Gears: Posi, 3.23
Car is an 87 Formula. I lifted my rear the other day to do new bushings and end links on the sway bar. I had the car on jack stands underneath the subframe causing my rear end to hang down freely. I noticed the passenger side spring was completely loose and wobbly and when I looked underneath it, I noticed that the whole upper spring seat is loose from the body of the car. I looked around and from what I can see there's only one whole in the body. I took the interior apart to see if there was a bolt or anything and I couldn't see anything.
I moved over to the driver side where the upper spring seat is still connected to the body but still can't figure out what's keeping it there. I don't really notice anything wrong back there unless I hit a big bump, then I can feel and hear a knock back in the area of the rear passenger side speaker.
Any insight would be greatly appreciated.
Old Jul 22, 2015 | 03:27 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Re: Issue with rear upper spring seat
Sounds like your shock is unbolted. Back behind the rear seat, under the carpet is where the shocks bolt. there will be a foam pad that covers the nut.
Are you talking about the metal coil spring or the shock?
Dan
Old Jul 22, 2015 | 03:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
There's nothing to hold the spring and its insulator in place except the car's weight.
JamesC
Old Jul 22, 2015 | 04:27 PM
defaced's Avatar
Engine: 355
Dan
I'm talking about the coil spring, shock is okay.
JamesC
I was also wondering this but I cannot budge the upper spring seat on the driver side. Just seems odd that the seat wouldn't be connected to the body of the car because if you hit a bump or a dip not only would the spring come down with the axle, the upper seat would come with it. Just doesn't seem right.
Old Jul 22, 2015 | 04:34 PM
JamesC's Avatar
Right or wrong, if you drop the rear end down far enough the spring and its insulator will nearly fall out. As a consequence swapping rear springs is a thirty minute job—if you stop for a cold one.
JamesC
Old Jul 22, 2015 | 05:27 PM
defaced's Avatar
Engine: 355
JamesC
Yeah I understand. Oh well, I'm not going to worry about it then. Thank you.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
sailtexas186548
Aug 26, 2015 03:32 PM
AkDrifted
Aug 17, 2015 07:45 PM
