vibration
Old Feb 26, 2016 | 12:43 PM
Bjerime01's Avatar
Car: Firebird
Engine: 5.0 TPI
vibration
Ok this is what I got and what I have done. I have checked rear trans shaft bushing seems to be tight I have turned drive shaft 180 out and just put new pinion seal and tighten all back down. I had drive shaft balanced and all new u-joints put in and still getting vibration in 2,3 and OD in mild pull. You can push the car hard and it almost goes away. Car has been lowered I think 3in's. Is there any way to set pinion angle with stock under bar or do I have to buy a adjustable bar?
Old Feb 26, 2016 | 11:24 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: vibration
Sounds like your on the right track, I would check your pinion angle. I'm pretty sure you're going to have to get an adjustable TA to correct it.
Old Feb 29, 2016 | 05:30 PM
Bjerime01's Avatar
Car: Firebird
Engine: 5.0 TPI
Re: vibration
Update well as the problem got worse I checked into the flex plate found one loose bolt. I tighten down and vibration is almost gone and then I got a bad clicking noise that got worse and worse. On further inspection I have found cracked flex plate. So I order all and will give update as I finish the job.
rickyzZ28
Feb 26, 2016 08:20 AM
LsxMatt
Feb 25, 2016 12:11 AM
Procharged GTA
Feb 18, 2016 09:17 PM
84strokerbird
Feb 18, 2016 02:21 PM
88RS
Jan 24, 2016 08:40 PM
