Front driver tire leaning
Car: 90 IROC-Z
I have a 90 camaro iroc-z and the driver side tire is slightly inwards at the top. I have had pretty much every thing you can name on the front replaced but i just cant seem to figure out the problem. also when i cut short the front wheels kind of drag along on one side. if you look at the front wheels you can visibly see the difference in how far they stick out. the shop i had the front end aligned only adjusted the toe. any suggestions????
re: Front driver tire leaning
Only one suggestion:
Take it to a different shop that will actually align the front end.
Thirdgen89GTA
Mar 18, 2016 06:41 PM
