Transmission crossmember a chassis stiffener?
Old Aug 14, 2016 | 10:59 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I've not found the definitive answer on this, Does the transmission's crossmember actually contribute to chassis stiffening. I am inclined to think that it does. I'm going to weld up my own transmission cross member for my T56 swap and I need to know if this piece needs to be a strong structurally linking piece or just strong enough to keep the transmission from falling down. I see designs like the Hawks, that are just bent metal plate/strap and I think they can't be adding to any chassis stiffening.
Then I see the Spohn and UMI and I think that they may be helping out to stiffen the chassis.
So what's the verdict? Is the transmission crossmember a needed chassis stiffener and the Hawks is a poor design and I need to put something together that works as a support or can I just use some simple angle iron and metal plate?
Old Aug 15, 2016 | 01:35 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Transmission crossmember a chassis stiffener?
it might not add a ton of stiffness to the chassis, but it has to be stiff due to the loads from the torque arm pushing up and down on it... i can feel the flex in the stock crossmember in my car since the T5 swap this spring by how much the shifter moves up and down when i get on and off the gas- if the engine is up in it's power band and i go to WFO or let off, the shifter moves straight up and down about 1/2" or so- and that's almost all crossmember flex since i put a poly trans mount in it last year.
Old Aug 15, 2016 | 08:44 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
don't forget BMR
http://bmrsuspension.com/
SR71BLKBRD
Mar 28, 2016 08:29 AM
CHAMARO
Mar 27, 2016 11:21 PM
mtz.luis
Mar 22, 2016 05:50 AM
gt4373
Mar 15, 2016 12:59 PM
Kat
Aftermarket Product Review
Oct 31, 2000 09:34 AM
