Having trouble bolting on A-arm
Old Aug 29, 2016 | 06:13 AM
ktthecarguy's Avatar
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Hi there,
I am rebuilding my front suspension and steering, and I am having trouble bolting the A-arm back on. I had the ball joint and bushing pressed in, and I got one bolt on (the front one) but I am having difficulty bolting on the rear (shorter) bolt. I can't get the bolt home to line up. I have tried using a hydraulic jack to try to press the bushing into place. I also tried using a small sledge hammer to bash it into place.
So far I can't get the hole to line up, no matter what I do. Does anybody have a tip or trick to getting the arm to go back in?
Old Aug 29, 2016 | 06:22 AM
Re: Having trouble bolting on A-arm
Put in the bolt that you can't get in now, first; then try to put the other one in.
A pry bar works MUCH better than a hammer... beating on a piece of rubber to try to change its shape isn't all that effective. Big pair of channellocks or a C-clamp are also a good way to press something pliable into shape.
Old Aug 29, 2016 | 07:41 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Floor jack to get it close. Pry bar to fine tune. And sometimes I stick a punch through the hole to get the hole aligned to get the bolt started.
As said, it mighht be easier to install the back first and then the front.
Old Aug 30, 2016 | 12:02 AM
On Probation
SUCCESS!
I tried Sofakingdom's suggestion and removed the one bolt and tried the other side first. Got it! then with a little fiddling got the first bolt back in. Now I just need to rent a spring compressor and I can reassemble the front A-arm.
Thanks for helping me with this. It was driving me nuts and took me 4 days to do it.
Old Aug 30, 2016 | 10:46 AM
Sometimes the simplest is the best.
Stangski09
Oct 16, 2016 07:59 PM
214jay
Sep 22, 2016 08:59 AM
venomous
Sep 14, 2016 01:10 AM
rwstegne
Aug 15, 2016 12:51 PM
Thirim
Aug 8, 2016 04:58 PM
