Brake Upgrade
Subscribe
Dec 28, 2001 | 09:55 PM
What is the number one brake upgrade? I have a stock '91 Camaro RS with the L03. Keep in mind budget...
Reply 0
Dec 28, 2001 | 09:57 PM
About the cheapest one that actually does anything is the 1LE conversion.
Reply 0
Dec 28, 2001 | 10:06 PM
Putting the larger 1LE front rotors and calipers on? Or the disc brake rear?
Reply 0
Dec 29, 2001 | 01:53 AM
Quote:
I was thinking the fronts. You could swap the rear to get discs on the back, but I don't think you'd notice as much difference.
Reply 0
Dec 29, 2001 | 05:43 AM
1LE on all four wgeels is about the cheapest You can get. And the difference in performance is unbelieveable.
Thanx,ANDYZ28
Reply 0
Dec 29, 2001 | 08:05 AM
Thanx for the advice. Would I have to change anything like the master cyliner or proportioning valve if I went with a 4 wheel 1LE disc set up? With just front wheel 1LE conversion?
Reply 0
Dec 29, 2001 | 09:04 AM
if you have a drum rear, you wouldn't need to change the proportioning valve. And for the street, drum rear is fine.
Reply 0
Subscribe
