Detroit Speed, Inc. 1982-92 F-Body Products
Car: 1988 IROCZ
Engine: ZZ4
Axle/Gears: MOSER 9"
Re: Detroit Speed, Inc. 1982-92 F-Body Products
It's a spherical bearing. I don't have a better picture, but it's shown here...
http://www.superchevy.com/how-to/041...ades/#photo-39
Ahhh, makes sense, would be easy to fabricate and has a wide range of motion. TA is designed to slide within the bearing under stop & go transition yes? About how much movement do you think? Did it require lubrication to prevent binding? If true, how do you keep dirt out or lube from washing away in the rain?
Thanks for the link.
Car: 1985 Firebird & 1992 Camaro B4C 1LE
Engine: 310 LS1. & 305
Transmission: TH350 & T5
Axle/Gears: 9" 3.73
Car: 1987 DSE-Z Camaro
Engine: 388ci LS7
Axle/Gears: Ford 9" DSE Full Floater
Here is a write up on our front Speed Kit 3 from our friends at Chevy High Performance Magazine.
I will also be dumping some videos of our test car here so you can see the products in action!
http://www.superchevy.com/how-to/cha...nsion-upgrade/
Car: 1991 Camaro Z28
Engine: 350 L98
That quadra link rear end looks great. Would love to get this and drop some of the extra parts out of the rear.
Any plans in a building a tubular k member?
Engine: 388ci LS7
Engine: 388ci LS7
We have a new product available! This item is included in the purchase of our Front Speed Kit 3 and Rear Speed Kit 2/3 or separately with the link below...
http://www.detroitspeed.com/1982-199...ker-decal.html
Engine: 350 L98
Ok next question. Will the quadrilink system on away with the rear seat?
Meaning will the upper arm boxes lose the ability to put the rear seats back in?
Engine: 388ci LS7
Car: '89 'ROC
Engine: 5.7L
I’m interested in hearing more from DSE on this product:
http://www.detroitspeed.com/1982-199...shaft-kit.html
Its main competitor seems to be the Astro van shaft. Outside of the vibration reducing joint, any other details?
Engine: 388ci LS7
To learn more about the steering shaft kit, please contact our sales and technical associates at 704-662-3272 or tech@detroitspeed.com.
Engine: 388ci LS7
The DSE-Z being put to work at Gingerman. Fastest time of the weekend was a 1:39.6.
Engine: 388ci LS7
2 and 3 Point Strut Tower Braces are in stock!
Will fit LS, TPI, and TBI Camaros at this time. We have not done a test fit on Pontiac models.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Would happen to have a drawing of this brace? Specifically bolt pattern and spacing? I already have drilled holes for a QA1 three point and I would love to use this one instead. However, I might be out of luck unless the mounting points are close enough.
Car: '89 'ROC
Engine: 5.7L
You guys are making some sick sick gear for the thirdgen so I say this with all due respect: if the $90 difference per each strut
https://www.detroitspeed.com/1982-19...-f-body-031024
versus what summit sells’em for
https://www.summitracing.com/parts/kon-8741-1030spt
is emblematic of the margin on all your stuff it occurred to me a minimal reduction in the prices might escalate your sales volume dramatically to a net benefit to your guys’ bottom line. I suspect way more dreamers than buyers at current prices and yes I get this stuff is premium and not developed and manufactured cheaply which I respect. Just a thought.
Cheers
Cheers
Car: '90 RS
Engine: 377 LSX
Cheers
Cheers
Car: '89 'ROC
Engine: 5.7L
Yeah I knew the Konis weren’t made by them obviously. I was just extrapolating to their stuff from the gap. Not apples to apples agreed. My suspicion remained though. Otherwise all great points.
